Index of /BM3-construction/
NameLast ModifiedSize
UpParent Directory
DirectoryCHARGER CURVES2017-07-29 17:51-
DirectoryRoboteq_settings_screenshots2017-07-29 17:51-
[SND]1-RC-safe-braking-test.mp42022-05-01 16:20 42984k
[SND]12mph-caster-shake.mp42017-07-26 01:59 373k
[IMG]12v_regulator.jpg2017-07-26 01:59 243k
[IMG]12v_regulator_bottom.jpg2017-07-26 01:59 199k
[SND]15mph.mp42017-07-26 02:02 20252k
File810_0276.JPG2017-07-26 01:59 119k
[IMG]810_0336-small.jpg2017-07-26 01:59 269k
[IMG]810_0347.jpg2017-07-26 01:59 216k
File810_0766.JPG2017-07-26 01:59 289k
File810_0892.JPG2017-07-26 01:59 172k
File810_0904.JPG2017-07-26 01:59 209k
File810_0907.JPG2017-07-26 01:59 330k
[IMG]arrive.jpg2017-07-26 01:59 305k
[IMG]assembledpod.jpg2017-07-26 01:59 122k
FileBM MK3 Power Wheelchair.pdf2017-07-26 01:59 1905k
FileBM2L.JPG2017-07-26 01:59 71k
[TXT]BM3 25 PIN CHARGE CONNECTORS.txt2017-07-26 01:59 1k
[IMG]BM3-drive-996.jpg2017-07-26 01:59 683k
[IMG]BM3-drive-small.jpg2017-07-26 01:59 109k
[IMG]BM3-drive.jpg2017-07-26 01:59 1620k
[IMG]BM3-ELECTRICS.jpg2017-07-26 01:59 204k
[IMG]BM3-lithium-15mph-powerchair-1-small.jpg2017-07-26 01:59 188k
[IMG]BM3-lithium-15mph-powerchair-1.jpg2017-07-26 01:59 813k
[IMG]BM3-lithium-15mph-powerchair-2.jpg2017-07-26 02:00 2856k
[IMG]BM3-lithium-15mph-powerchair-3-crop.jpg2017-07-26 02:00 874k
[IMG]BM3-lithium-15mph-powerchair-3-small.jpg2017-07-26 01:59 125k
[IMG]BM3-lithium-15mph-powerchair-3.jpg2017-07-26 02:00 847k
[IMG]BM3-lithium-15mph-powerchair-4-small.jpg2017-07-26 02:00 712k
[IMG]BM3-lithium-15mph-powerchair-4.jpg2017-07-26 02:00 775k
[IMG]BM3-lithium-15mph-powerchair-5-medium.jpg2017-07-26 02:00 653k
[IMG]BM3-lithium-15mph-powerchair-5-small.jpg2017-07-26 02:00 127k
[IMG]BM3-lithium-15mph-powerchair-5.jpg2017-07-26 02:00 525k
[IMG]BM3-lithium-15mph-powerchair-6.jpg2017-07-26 02:00 987k
[IMG]BM3-lithium-15mph-powerchair-7.jpg2017-07-26 02:00 970k
[IMG]BM3.jpg2017-07-26 02:00 774k
[IMG]BMW-pump1.jpg2017-07-26 02:00 102k
[IMG]charge-balance.jpg2017-07-26 02:00 90k
[IMG]charge-cable-40A.jpg2017-07-26 02:00 399k
[IMG]charge-cable-connector.jpg2017-07-26 02:00 436k
[IMG]charge-cables-pl8v2.jpg2017-07-26 02:00 1630k
[IMG]CHARGERANDCABLE.jpg2017-07-26 02:00 330k
[IMG]charging.gif2017-07-26 02:00 204k
[IMG]Charging.jpg2017-07-26 02:00 291k
Filecomparaison_power.pdf2017-07-26 02:00 150k
[IMG]connector.gif2017-07-26 02:00 8k
[TXT]Control Script.txt2017-07-26 02:00 47k
[TXT]control-script-bot.txt2017-07-26 02:00 47k
[IMG]current-sensor-parts.jpg2017-07-26 02:00 142k
[IMG]current-sensor-rear.jpg2017-07-26 02:00 88k
[IMG]current-sensor-soldered-crimped-anderson-heatshrink.jpg2017-07-26 02:00 127k
[IMG]current-sensor-soldered-crimped-anderson.jpg2017-07-26 02:00 66k
[IMG]current-sensor-soldered-crimped.jpg2017-07-26 02:00 120k
[IMG]current-sensors.jpg2017-07-26 02:00 125k
[IMG]D8E_3794.jpg2017-07-26 02:00 119k
FileD8E_4061.JPG2017-07-26 02:00 937k
FileD8E_4069.JPG2017-07-26 02:00 870k
FileD8E_4112.JPG2017-07-26 02:00 173k
FileD8E_4308-small.JPG2017-07-26 02:00 193k
FileD8E_4308.JPG2017-07-26 02:00 685k
[IMG]fitted.jpg2017-07-26 02:00 259k
FileGREEN.JPG2017-07-26 02:00 250k
FileGREEN2.JPG2017-07-26 02:00 309k
FileGREEN3.JPG2017-07-26 02:00 272k
[IMG]joystick-pod-home-made.jpg2017-07-26 02:00 101k
[IMG]led-bluetooth-hyperion-charger.jpg2017-07-26 02:00 156k
[IMG]Lithium-powerchair-1.jpg2017-07-26 02:01 5276k
[IMG]Lithium-powerchair-10.jpg2017-07-26 02:01 1515k
[IMG]Lithium-powerchair-11.jpg2017-07-26 02:01 2207k
[IMG]Lithium-powerchair-12.jpg2017-07-26 02:01 1916k
[IMG]Lithium-powerchair-13.jpg2017-07-26 02:01 3107k
[IMG]Lithium-powerchair-14.jpg2017-07-26 02:01 2638k
[IMG]Lithium-powerchair-2.jpg2017-07-26 02:02 6026k
[IMG]Lithium-powerchair-3.jpg2017-07-26 02:02 5656k
[IMG]Lithium-powerchair-4.jpg2017-07-26 02:02 6152k
[IMG]Lithium-powerchair-5.jpg2017-07-26 02:02 5767k
[IMG]Lithium-powerchair-6.jpg2017-07-26 02:03 5953k
[IMG]Lithium-powerchair-7.jpg2017-07-26 02:03 5186k
[IMG]Lithium-powerchair-8.jpg2017-07-26 02:02 1632k
[IMG]Lithium-powerchair-9.jpg2017-07-26 02:03 1741k
[IMG]LITHIUM.jpg2017-07-26 02:02 68k
[IMG]Nandol-Beach-FAT-TYRES.jpg2017-07-26 02:03 114k
[IMG]PL8.jpg2017-07-26 02:03 180k
[IMG]pod-done-wired-finished2-small.jpg2017-07-26 02:03 57k
[IMG]pod-done-wired-small.jpg2017-07-26 02:03 95k
[IMG]pod-done.jpg2017-07-26 02:03 86k
[IMG]pod2.jpg2017-07-26 02:03 76k
[IMG]pod3.jpg2017-07-26 02:03 62k
[IMG]pod4.jpg2017-07-26 02:03 86k
[TXT]power sub d connectors.txt2017-07-26 02:03 1k
[IMG]powerchair-electrics1.jpg2017-07-26 02:03 207k
[IMG]powerchair-electrics2.jpg2017-07-26 02:03 155k
[IMG]powerchair-electrics3.jpg2017-07-26 02:03 177k
[IMG]powerchair-electrics4.jpg2017-07-26 02:03 177k
[IMG]range.gif2017-07-26 02:03 28k
[SND]RC-BM3.mp42017-07-26 02:05 25544k
[IMG]rear-light-rc.jpg2017-07-26 02:03 200k
[IMG]relay.jpg2017-07-26 02:03 222k
FileRoboteq BM3 Profile.xml2017-07-26 02:03 37k
[IMG]roboteq1.jpg2017-07-26 02:03 279k
[IMG]seat-tray-electronics-2.jpg2017-07-26 02:03 495k
[IMG]seat-tray-electronics-3.jpg2017-07-26 02:03 543k
[IMG]seat-tray-electronics-4.jpg2017-07-26 02:03 390k
[IMG]seat-tray-electronics.jpg2017-07-26 02:03 426k
[IMG]shaun1.jpg2017-07-26 02:03 132k
[IMG]shaun2.jpg2017-07-26 02:03 104k
[IMG]speed graph.jpg2017-07-26 02:03 100k
[IMG]usersettings.gif2017-07-26 02:03 173k
