by Burgerman » 05 Feb 2026, 22:10
I dont really understand how you found motor cables as they are normally soldered into the inside of the motor casing.
They are generally not as big as they would really want to be. Thats because in order to pull the full 120A then the motors internal windings would also need to be more substantial with more mass.
What happens is this.
Motors stalled. It CAN pull up to 120A from the controller. Only for a couple of seconds to dig itself out of a hole. During that few seconds the cables get hot. You can actually smell them, like a burned PVC smell. During this time the motor windings are also overloaded. They also have to suffer 120A and are not turning if stalled, and even if turning slowly theres almost no forced airflow inside the case. Once ROLLING that motor is spinning at 4 or 5 thousand RPM. That shoves a lot of air around inside the motor and cools the copper armature and heats up the air and the outer casing. That loses heat to the enviroment.
If the chair is stalled, pulling 120A from a motor for long it will burn out the motor before the cables melt. So the CONTROLLER watches for several things.
YOU set in programming how much boost current is allowed. And for how long UP TO 10 seconds.
You set the "normal" current level. This is typically 80 to 100. This current is dropped to a lower figure after a few seconds too due to
a) time based settings
b) stall settings in seconds
c) temperature.
ALL three are used to limit current (the temp one is the mosfet temperature, which is used as a proxy for motor temperature as these will heat up when loaded too)
So the too thin motor cables are protected! As long as not "too thin"...
Also consider this.
A motor on a 24V system, that is connected to a 120A controller may be 350 up to maybe 500 watts rated motors. But at 24V x 120A = 2880 watts.
So at stall, or when doing steep ramps, curbs, turn in place, steep hills you are feeding a 350 watt motor nearly 3 killowatts... This is why they must be "rolled back" after a few seconds, and why the chair manufacturers get away with smaller wires than you would expect.
Also WHO are you emailing???
