PINNED - R-Net for dummies
Re: PINNED - R-Net for dummies
Postby snaker » 08 Apr 2026, 10:42
@Burgerman: Do you know what terminal sizes match the power and motor pins on r-net PM?
Postby Burgerman » 08 Apr 2026, 11:04
I think they are 9.5. and EITHER 4.8 or 6.3.
Dont shoot me when I am wrong! I just dig into the draw and see what fits!
https://www.arc-components.com/0-005-24 ... -3157.html
These are for bigger cables...
The small ones (brakes) may be 4.5 or 6.3...
Postby snaker » 22 Apr 2026, 03:58
I am testing the open r-net project. I cannot make the PC see the r-net PM through an usb-to-can adapter.
I have some questions:
When using an oem dongle, how do you connect it to the PM?
Do you directly connect it to the 4-pin hole on the PM?
Or do you indirectly connect it to the 3-pin hole on the joystick?
In the case if you directly connect it to the 4-pin hole on the PM, do you need to connect the PM to the joystick first to trigger the programming mode?
Postby Burgerman » 22 Apr 2026, 07:13
I put it BETWEEN the pod and the joystick, but it works on any spare bus cable you may have.
Postby duke1 » 23 Apr 2026, 21:33
hi all is there any seller in particular selling a 120 amp rnet system? zero results on ebay only 90amp. i am debating replacing the dynamic dx2 system on both our chairs as they have become troublesome now and with my dwizz adapt dying a death it seems daft spend hundreds of pounds on replacing it and maybe better changing to more modern system,but i would then need programmer and if anything like the wizard 5 prog then it can bog off!took me 6 months to make that work being as i had never used a computer before that for anything other than browsing internet, so if anyone can point me the right way it would help,im lost again, :joint ps i have programer for vr2 would that work on rnet?cheers for any info. cheers
duke1
Postby Burgerman » Yesterday, 00:14
There are always some. Usually at the wrong price.
Like these 2.
https://www.ebay.co.uk/itm/206035076975
https://www.ebay.co.uk/itm/236196180316
You got to be patient. I got 4 now and the most expensive was 50, and the cheapest was 50 inc a lighting/seating module and 2 bus cables.
40 to 45 is the going rate if like new.
To program you ned an r-net dongle and software I have links to.
Users browsing this forum: DennisinTexas, faico_26, jefferso, shirley_hkg and 492 guests
