From the inner surface of the rim where the bolt hole is, to the inner edge of the tyre is 39mm
Thats the one. Thats all thats required.
Why? Because we know the stock tyre width is a nominal 3.00 inches in size.
So we now calculate how thick the spacer should be to fit x wheel (many wheels are all different offsets so we just measure a wheel that we want to use) to put the inner tyre edge the same distance from everything that it is as stock.
Now this usually works out great with around a 10 to 12mm thick spacer on the rims/120 tyres I use. Much nmore difficult on skinnyer tyres. Because it can mean an impossibly thin or minus thickness spacer... Which then means finding a wheel with a bigger offset.
