R-Net PC Programmer OEM
Re: R-Net PC Programmer OEM
Postby Burgerman » 24 Apr 2018, 18:35
All software works with both dongle levels. At the lowest of whichever is the lowest... OEM needs both soft, and dongle at OEM level.
Postby rover220 » 25 Apr 2018, 06:03
it is posssible to use a dealer dongle to do oem programming though but needs a little work around
Postby steves1977uk » 25 Apr 2018, 10:02
Yes, you can program OEM settings with a Dealer dongle as I've helped expresso and a few others do this. :) :thumbup:
Postby stoffhund » 26 Apr 2018, 06:24
Where can I get an R-Net dongle type B?
or can you simulate and simulate something like this with a mini computer "Adurino"?
stoffhund
Postby Burgerman » 26 Apr 2018, 09:17
The manufacturers dont want us to have OEM level programming tools. They dont even want dealers to have them. Some manufacturers even deny they exist. Which means most people are suffering unusable, unsteerabe, locked down wheelchairs or cannot reconfigure or sort out things that they wish to do. Why? Because they presume that we are all idiots. And they presume that the manufacturers know best. It seems that in most cases the opposite is true.
You can search for the powerchair soccer site. They will sell you a programmer, but not cheap, and you will likely pay customs charges if you are not in the US.
Postby expresso » 26 Apr 2018, 15:39
stoffhund wrote:Where can I get an R-Net dongle type B?
Check your PM -
Postby hotwheels_75 » 26 Apr 2018, 20:54
steves1977uk wrote:Still using Pilot+ here, but do have a 120A R-Net PM and CJA to use, just gotta find someone to help me fit them! :hammer
Do you have to rewire your motors or anything for that swap? I’d like to upgrade my current Pilot+ setup as well and was looking at the 120A R-Net.
hotwheels_75
Postby steves1977uk » 26 Apr 2018, 21:37
Nope, as the Pilot+ and R-Net uses the same battery and motor plugs. Just make sure the R-Net settings are correct! :thumbup:
Postby hotwheels_75 » 26 Apr 2018, 22:59
Sweet! I thought they looked similar looking at pics. That’s awesome. Now I need to source some parts. I read the post earlier that someone purchased directly from P&G , but when I emailed them they said they don’t sell directly to consumers?
hotwheels_75
Postby steves1977uk » 26 Apr 2018, 23:12
That would be me, as I managed to get the battery and motor connector kits directly from PGDT. I just said to them my motors needed new plugs and I needed to make a new battery cable to the PM and PGDT sold me the required kits. I did also mention that I rebuild my chairs, so new parts are needed.
Postby hotwheels_75 » 27 Apr 2018, 00:16
Good to know! Maybe I’ll try that angle if I can’t find a used set.
hotwheels_75
Postby steves1977uk » 27 Apr 2018, 15:08
It's worth a try! :thumbup: The first time I tried to get the connector kits I was told the same thing, but the second time I mentioned that I rebuild my chairs, PGDT sold them to me without any hassle.
Postby hotwheels_75 » 09 May 2018, 15:23
Well I tried, no luck. They still said they don’t sell direct. They gave me contact info to their distributor who has yet to respond to my request for prices and availability. :thumbdown:
hotwheels_75
Postby steves1977uk » 09 May 2018, 21:36
Guess it depends on which person you get, as one tells you you can't buy them directly and another have no problems selling you the kits. :?
Postby hotwheels_75 » 09 May 2018, 21:52
Yeah, that’s what I figured. I got the same person both times I emailed. Did you email or call?
hotwheels_75
Postby hotwheels_75 » 09 May 2018, 22:45
So with the available R-Net programming software mentioned in this thread, if I buy an R-Net controller, joystick etc. online, will I be able to program everything to work with my motors etc?
hotwheels_75
Postby Burgerman » 10 May 2018, 02:55
The rnet requires a dongle. That is essential. And its in 2 versions. Dealer (very basic) or OEM (what we need!) and they wont easily sell us OEM... But theres a way.
Postby steves1977uk » 11 May 2018, 09:51
hotwheels_75 wrote:Yeah, that’s what I figured. I got the same person both times I emailed. Did you email or call?
I e-mailed both times since I'm unable to use the phone.
Postby elryko1992 » 19 Jul 2018, 18:17
check PM bborgers,
elryko1992
Postby Furio » 22 Jul 2018, 17:31
I am lost in trying to configure IR on cjsm2 joystick. :cussing Any help would be appreciated . :worship Thanks.
Furio
Postby Burgerman » 22 Jul 2018, 17:35
What are you trying to do. Worked very easy here!
I just chose my TV from the list, renamed, and so on. And thats it.
Postby Furio » 23 Jul 2018, 17:33
The TV can be switched on with joystick. But media is connected through a set top box and the HDMI
output from it goes to TV.The channels are changed from set top box with remote. Here the set top box does not
respond to joystick though I configured it as CABLE/SATELLITE. :problem:
Furio
Postby Burgerman » 23 Jul 2018, 17:36
Well that depends on your specific cable box and its remote. You may need to teach it the commands. Which is a pain in the backside. But once done should be fine. As a different device obviously.
Postby Rye » 23 Jul 2018, 20:22
Is there separate Rnet ICS module PC programming software? I was able to find the programming manual for the ICS, but the ICS isn't sshowing up on the Dealer or OEM pc software. Does it have to be unlocked in some way?
Rye
Postby Burgerman » 23 Jul 2018, 21:10
Theres a seperate bit of software called something builder. But I doubt thats the error codes you see. And no we dont have that. Its why I wouldnt buy a permobil. And the fact that they only do mid/front drive now!
Postby Burgerman » 23 Jul 2018, 21:17
In the SUNRISE OEM theres a section in seating specifically for them. I presume that the permobil OEM will be the same. Not sure if this is related to the module you are talking about or not. No idea how that permobil ICS thingy works. But other manufacturers do something similar on certain chair options. But non I ever played with. Rover may know?
Postby Rye » 23 Jul 2018, 21:55
My programmer shows ISM and SM, but no ICS. Mine is definitely an ISM. Maybe someone will chime in with the answer...
Rye
Postby Burgerman » 23 Jul 2018, 22:47
You will not see the ICS settings below, unless using the OEM Permobil version of the R-Net software. In the same way that you see Sunrises special customization in the sunrise version, with very similar settings.
The actual stuff you will see is dependent on whatever they did with their ICS and their Permobil branded "Wheelchair Builder" software. Are you using Permobils R-net software? The generic, or Sunrise versions will not see the ICS thingy or its settings. That is custom software to permobil only.
Postby Rye » 23 Jul 2018, 23:02
Correction: Mine is definitely an ICS. It doesn't show up anywhere under seating.
Rye
Postby Rye » 23 Jul 2018, 23:09
I have several versions of the programmer. All my OEM versions may be generic.
Got an Permobil OEM version?
Rye
Users browsing this forum: No registered users and 392 guests
