woodygb wrote:Denis are the motors all the same or odd pairs?
Hi, are there any more pictures showing inside the motors? Specifically the brake mechanism.
RoyOnWheels wrote:woodygb wrote:Denis are the motors all the same or odd pairs?
Burgerman wrote:Why the white masks? Traffic fumes?
You need more speed![]()
shirley_hkg wrote:[That's why we stick to it. That will be great if someone can put Roboteq dual channel gearless controller to them. One has tested these motors can run over 400 rpm ; that's over 25 kph. WOW.[/color][/size]
shirley_hkg wrote:We spent our 4 day Easter holiday for good foods.
http://bbs.4limb.org/viewthread.php?tid ... ra=&page=3
Have to get to town first , for 35 km from the nearest railway station.
This is how we ride : https://www.youtube.com/watch?v=TT53Cl1 ... e=youtu.be , and why we love our GB chairs , lithium powered.
denis.b wrote:I thank all of you who helped me build the wheelchair.
I have been using it in the mountains for more than 7 years and it has always worked very well on very steep and safe roads thanks to the four bruschless motors with electric brake. With 8 LIFEPO4 lithium polymer batteries of 200AH and 26Volts average I have a huge range. At 10Km / h it consumes less than 10Ah traveling on a level I have a range of about 200Km.
I wanted to ask you if it is possible to reprogram the MKIV GB control unit to remove the speed limit which intervenes at about 12.5 km / h and decelerates the wheelchair until it stops.
Thank you
Thank you
denis.b wrote:The joystik command has been rebuilt. I can turn on with only front or 4x4 drive. The two control units simultaneously receive the data line from the joy, to enable 4x4 sending + 13V when the second control unit is switched on.
Users browsing this forum: jefferso and 387 guests
