martin007 wrote:Loctite is cyanocrylate.
In the short term cyanocrylate in contact with water or moisture degrades.
50ml sizes but this stuff is basically fit once! Hope you never need to dissasemble. For things you never want to come apart!
https://www.threadlockeruk.com/products ... e-272-50ml
Add 450C heat makes it let go.
This blue one, also available 50ml, as well. I use the blue one for loads of things. You CAN undo stuff you use this on, but it certainly grabs... And stops corrosion etc. Mines 50ml...
https://www.threadlockeruk.com/products ... e-243-50ml
Theres many others. These are all you need.
These two both work without activator. But a hell of a lot better with it. Esp the red one. Use the red one on clean threads and its like its welded on!
Users browsing this forum: anttttttt, Bing [Bot] and 538 guests
