Not according to the workshop manual. It shows how it come apart and explains in painting by numbers style how. 2 bearings, how to be sure they are the right side up, which is obvious, and how to tap the old ones out. Just like all chairs/bearings.
https://www.polybush.co.uk/This stuff, not nesassarily this colour! Or brand. Can be clear, any colour. May be bonded to the arm, etc.
Its just like many others except that it uses a urethane "polybush" softer" mount for the bearing tube the bearings tap into. That bit of polyurethane tube allows the caster momunt and bearings to have some flex. Its not suspension as such, its just a slight flexibility between bearing tube and arm.
Not sure its a good idea either as it does nothing to absorb vertical movement which is whats required. Just pushes back a fraction of a degree as the caster sees an obstacle. Its marketing suspension... I used those same urethane polybush things to replace the stock rubber ones on my cars 3 decades ago. They work ok and are tough. But allows more tyre noise and vibration through. But improves handling as its less "wobbly" and more positive.
