I have rnet own dingle and program.the chair has non screen version of rnet joystick.wilk programmer work I hsv3 used in chairs with screen on rnet joystick work ok to program speeds
Sorry if my question was not clear my disability effects my hands so typing is hard. I have OEM programmer . laptop with rnet software. I am asking will that work to program Q300m Mini that has a RNet LED Joystick ( not a LCD screen version which I've programmed in the past on other chairs). See link below of joystick. Will I be able to program the speeds on the chair still??
When you program a chair then you are actually programming inside the power module. And joysticks are interchangable. All work on all chairs.
Only joystick specific items such as remapping buttons on the fancy CJSM2 joystick will not work with LED joysticks. Because they dont have those buttons. Everything else is the same.
Thank you that's great. yes I know it's program in the rnet module.so the module is the same then. Is there a fashion of the programming software that is specific to that particular Wheelchair make and model? If so, do you know where I can download it from and any tip specific to that chair?
What chair? What software do you have? What version?
There are a few differences in power modules, different power levels etc, so you need to take that into account or not change thigs you dont understand... But different manufacturers may have some differences in what you will see listed in the menus. And matches custom firmwares etc. Mostly the same though.
