pm bad cable 7f00
pm bad cable 7f00
Postby BCrip71 » 26 Feb 2025, 20:55
If I am getting a PM bad cable 7f00 error when I plug in one joystick and not another, is it safe to say it is the joystick cable?
BCrip71
Re: pm bad cable 7f00
Postby Burgerman » 26 Feb 2025, 20:59
Or maybe the joystic end needs a spray of switchcleaner? Or is a faulty joysick. Be careful some joystick cables are not removable without a soldering iron.
Postby BCrip71 » 26 Feb 2025, 21:32
The chair still works but, just alternates ISM and JSM errors.
How would I know if the cord can be unplugged from the bottom of the joystick?
BCrip71
Postby Burgerman » 26 Feb 2025, 21:44
If it doesent unplug easily like a normal r-net cable its soldered! ALL my 3 in use on sunrise chairs are non removable. All the three spare ones I have in a box are the same. Only ever saw one that was removable. Open it and look if need be.
Well they are all removable really, just needs an iron.
Postby BCrip71 » 26 Feb 2025, 21:55
So it cannot be fixed?
BCrip71
Postby rover220 » 26 Feb 2025, 21:58
Bus cable to joystick.
Postby BCrip71 » 26 Feb 2025, 22:02
rover220 wrote:Bus cable to joystick.
How do I replace it?
BCrip71
Postby Burgerman » 26 Feb 2025, 22:29
Take apart. Or remove if removable. Order new if removable, or get replacement from PGDT and/or fix it if not.
I might get a cable on ebay or fix it as not cheap!
This shows the permobil joystick (he thinks its a smaller version of the CJSM2 but its really branded and made for permobil alone) has a removable cable. But he may be wrong. I saw a removable one once and I am sure it wasnt permobil but a real CJSM2 but I could be wrong, wasnt paying attention.
If its not removable, then it actually still is, you just need a soldering iron. Only 4 wires not hard to do. Well I didnt actually do it, but I have seen it internally. Should be easy enough.
https://www.youtube.com/watch?v=hQrwEItrP_w
Users browsing this forum: Burgerman, shirley_hkg and 592 guests
