Balance wiring question...
I'm about to install the old Headway cell packs I've built up, and had a question about the balance wiring...
They are built as 2 4S6P packs with balance wiring between each serial pair. My question is about the wiring between cells 4 and 5 (The + on one pack and - on the second)
My current lead bricks are wired up with Andersons as BM suggested in the past to allow charging from my van, and I'd like to keep that wiring setup to allow an occasional use as a 12V power source and to allow doing an emergency recharge from the van if needed....
I had planned on running an AWG 22 balance wire to each string even though they will also be connected (in 24V configuration) by the main power wiring (AWG 6) as well. I know that BM and others have said that this is the best way to wire the two packs, but if I do it this way, then it seems like BAD THINGS would happen if I then put the 12V plug in as it would mean a dead short via that 22G wire for the few seconds it would take to melt
Or if I accidentally disconnected the 24V jumper and tried to drive the chair, which would mean an AWG 22 link between the two packs...
To avoid this, is there ANY reason I can't simply only connect that balance wire to ONE of the two packs and simply rely on the power wiring for the balance connection between them? If I do it that way it seems totally safe. Would it make any difference which pack I connected to?
However I found after some experimenting that they WOULD work as 4S pack testers and that they were fine if I wired one to test the 8S pack as 4 2S packs in series - IOW nominally I should get four readings that are 2X the single cell values.... Not ideal but I don't think it is likely that I'd have a pair of cells go out of balance in opposite directions, which is what would have to happen in order for one to drop dangerously low, especially if I add in some 'fudge factor' on deciding when to charge...
Getting rid of range anxiety is a real thing!
