Batteries for Q500R
Batteries for Q500R
Postby Potty » 01 Sep 2025, 10:20
Hi all,
After advice from BM and others a while back(thanks), I've finally changed the Karma Blazer for something more suitable a Quickie Q500R(group 24, 6mph, 4 pole, currently VR2, but aim to change to RNET in time)
It needs batteries, I do plan to go down the DIY 230ah lithium route in the not too distant future, but need to get something half decent in the mean time. (Once I am set up with the DIY I will re-use these batteries in my wifes mobility scooter, which is also group 24)
Reading the older pinned threads, it would seem lead gel 74-80ah is the best option, but reading some more recent posts, it seems that maybe the 100ah group 24 drop-in litiums may be up to the task these days? At a similar cost.
I've found these https://uk.renogy.com/products/core-12v ... ag_organic
Would this work please? Or are there any better drop-in options?
Thank you :)
Potty
Re: Batteries for Q500R
Postby Burgerman » 01 Sep 2025, 10:36
It should. Just about. You would be pushing them a lot if the chair is programmed like mine is. If you drove it lIke you stole it.
Beware that the BMS dont generally like being pushed hard either and tend to be rather optimistic in their claimed capability. Or at least dont do it for very long.
And the batts might not last as long as you are expecting. How long? How long is a peice of string! So the answer is a firm, probably!
However it seems a bit silly really as you are getting 20Ah more than lead. And you need to save 20% (or 20Ah) in reserve anyway or it will suddenly stop or whatever under load due to voltagge drop, or a low cell, and to get a sensible cycle life. So since lithium will give around 70% more range Ah per Ah (because peukert) you will end up with a 50% range gain over lead if nothing fails...
But with the same cost, you can get 230h (244 measured) and get a huge lifespan as you wont be leaning on them! And if you leave the same in reserve you will get around 5x the range of lead. But more work to do.
Postby Potty » 01 Sep 2025, 10:43
Burgerman wrote:It should. Just about. You would be pushing them a lot if the chair is programmed like mine is. If you drove it lIke you stole it.
Thanks for the fast reply :)
I would say I push my chairs pretty hard(for factory setting!) in terms of inclines/offroad/grass etc, but this will be in hovercraft mode until I can find all the RNET parts for the right price :thumbup:
Potty
Postby Potty » 01 Sep 2025, 10:49
Burgerman wrote:However it seems a bit silly really as you are getting 20Ah more than lead. And you need to save 20% (or 20Ah) in reserve anyway or it will suddenly stop or whatever under load due to voltagge drop, or a low cell, and to get a sensible cycle life. So since lithium will give around 70% more range Ah per Ah (because peukert) you will end up with a 50% range gain over lead if nothing fails...
Totally agree, but as I need something now, it's basically drop in litium or lead, so I assume for the same price (Haze 80ah for example are exactly the same price), having the bit extra range and potential for longer life span, would be worth it?
I would guess I tend to do about 5 miles a day(not flat), but sometimes want to be able to do say 8-10 or so.
By the way, given the voltage range, will I just be able to use the factory charger? Or lithium charger still needed?
Whatever I get will atleast be re-purposed in my wifes scooter, her currently batteries are getting on, though she only uses it once every couple of weeks.
Potty
Postby Burgerman » 01 Sep 2025, 10:50
But thats the point. That stops you taking even half the battery power out that I can.
Thats the reason I would make them trip and die fast. I tied this already. With a 100A BMS I can make a chair trip literally 1 second after I hit the stick! With a 200A BMS I cant make it trip at all. As they can do more, for the short periods needed. But they still do screwy things. And the cells really dont like it.
Postby Potty » 01 Sep 2025, 10:52
Burgerman wrote:But thats the point. That stops you taking even half the battery power out that I can.
One of my goals is to do a BM style wheelie :D
But not till I get the DIY 230ah and RNET sorted...
Potty
Postby Burgerman » 01 Sep 2025, 10:56
Postby Potty » 01 Sep 2025, 10:59
Burgerman wrote:How to draw a lot off current.
:thumbup: How many amps would you guess that initial burst is?
Potty
Postby Burgerman » 01 Sep 2025, 11:18
That chair is very limited. Its got a 80A per channel controller. I measured that and it pulls 84A (thats its actual limit) per motor. At full throttle accelerating it pulls double that the battery. At lower speeds like when making the front jump its less though.
A Bigger heavier 120A R-net, like the salsa does 240A intermittently at the battery mostly around 200 max.
Postby Potty » 01 Sep 2025, 11:26
Burgerman wrote:That chair is very limited. Its got a 80A per channel controller. I measured that and it pulls 84A (thats its actual limit) per motor. At full throttle accelerating it pulls double that the battery. At lower speeds like when making the front jump its less though.
Ah I see, did not realise that kind of "take-off" would be possible using a 80a controller :thumbup:
By the way could you recommend a charger for these drop in lithiums please, or will they be ok using the standard Quickie charger?
Potty
Postby Burgerman » 01 Sep 2025, 11:49
It is, if your chair is programmed to turn when you say so. And go when you tell it.
Re: Batteries for Q500R─=≡Σ((( つ•̀ω•́)つ动感光波哔哔哔!!
Postby shirley_hkg » 01 Sep 2025, 13:51
Potty wrote: so I assume for the same price (Haze 80ah for example are exactly the same price), having the bit extra range and potential for longer life span, would be worth it?
Same price ? I'd give the lithium a go. It supports 300 amp for a few seconds, so may not tripped if you don't abuse it.
Postby Burgerman » 01 Sep 2025, 14:22
I would never buy lead at todays prices. The argument now is just lithium drop in bricks, or lithium done properly. Because its got to the point where all three ways are about the same price!
So its:
1. Lead, 12 to 15 miles, lasts a year maybe 18 months. Lead is over.
2. Drop in lithium bricks like the ones you linked (most wont work) 16 to 25 miles, lasts?? Reliability? We cant tell, depends on battery cells, BMS, chair, pogramming, use etc.
3. 230Ah lithium, hobby charger, 100 miles range, 3 decades or longer than you, 10k cycles, charge now and again...
Postby Burgerman » 01 Sep 2025, 14:45
The only time that it MAY trip is if:
Battery is say 70 or so % discharged, and you then gun it. Or try to climb a ramp. Because it will have a BMS that is monitoring cells, and the added sudden load does not need to hit an overcurrent situation, to make a battery cell drop its voltage below the cell protection threshold. We dont know what that threshold is set to, how long it must be at that point, or what the cell int resistance actually is when the battery is low.
OR / AND
The typical BMS balance current is low, internal self discharge currents have unbalanced it over time and the balance circuits dont get enough time to balance it. So as you roll, a cell drops down lower than the rest way earlier than you expect.
But its says it has BT and so I presume you will be able to monitor this towards the end of a charge or busy day???
Those batts are one of only 3 I ever saw that I would even bother with as drop in replacements to try. But they are not cheap, for only 100Ah. They do iuse prismatic cells though. Those are generally 1C rated. These are allowing 3C... So not sure that is a good sign for longevity! But it is what it is.
Postby Potty » 01 Sep 2025, 15:43
Thanks, I actually found a 10% discount code, so they worked out £40 cheaper for the pair, than the cheapest decent gel ones I could find.
Potty
Burgerman wrote:It is, if your chair is programmed to turn when you say so. And go when you tell it.
Nice, I may need to look into vr2 programming :shifty:
Potty
Postby Potty » 01 Sep 2025, 15:47
Burgerman wrote:The only time that it MAY trip is if:
OR / AND
I'll let you know how I get on with them :D
If the BMS does trip, is there an eay way to get it going again while out and about? I had read that it needs the charger plugging in to reset it, so wondered if keeping a charger and small portable power supply in my bag would be wise?
Potty
Postby shirley_hkg » 01 Sep 2025, 15:53
Or a main switch to disconnect it, and switch it on again.
Postby emilevirus » 01 Sep 2025, 16:08
Don't go with Renology, They use proprietary BMS. Go with a battery with JK BMS so you can use the app and remove all protections. Been using one for 2 years, no issue.
emilevirus
Postby emilevirus » 01 Sep 2025, 16:14
I use this: https://www.aliexpress.com/item/1005004845282029.html
emilevirus
Postby Burgerman » 01 Sep 2025, 16:29
Thats 29.2V and only 10A so all night long to charge say 80Ah back?
You want around 3.550Vper cell. So 28.4V for full chair batt. Or it will do some cell murdering while it balances!
Plus its 240 watts. But claims 29.2V and 10A. Which would actually be 282 watts even if it was 100 percent efficient and it says its 85%... So whats going on there?
I would get one of shirleys power supplies and set that at 28.2 or 28.4V and set to say 15 to 20A. Yes its not so cheap...
That way when you want to charge a bigger 230Ah battery, it can, at anything up to 50A. And it can power anything else such as a hobby charger, or charge a lead chair correctly too (its also a 3 stage charger as well as a power supply and very configurable to set termnation currents, float voltages etc auto off, etc. And up to 3000 watts output. So a real tool! Built to survive telecoms rack use.
https://www.wheelchairdriver.com/board/ ... start=1920
Postby emilevirus » 01 Sep 2025, 16:33
The new EVE 105Ah are 3c rated. Mine must be because even at 3.1v/cell I can still climb a hill and pop wheelies without hitting LVC.
I have these: https://www.walmart.com/ip/Mehrpow-12V- ... 5630622130
50 cycles and no issue so far! Uses JBD BMS
emilevirus
Postby emilevirus » 01 Sep 2025, 16:39
For my 230Ah I do use shirleys psu I put a Xt90 directly on the battery.
But on my other chair it has two battery box with 2x anderson on each box. That chair is govt provided so can't really tamper with it so I just use xlr port. Takes like 9h to charge but I dont mind. It's my outdoors chair.
emilevirus
Postby Burgerman » 01 Sep 2025, 16:43
Thats easy, because those are huge, way too long by 3 inches to fit in a grp 24 chair. 100Ah in that size has been around a decade. So that battery should really be about 150Ah. It isnt because its either wasting space, or using thicker plate 3C cells or a physically large BMS?
Grp 24 100Ah batteries are a rare breed if they can also make 200A without damage... Infact even finding 100Ah ones isnt easy. 260mm long, not 330...
Postby emilevirus » 01 Sep 2025, 17:14
They're everywhere if you look on Temu, Amazon, AliExpress. Just need to be careful about the cells they use. Cheap ones use used cells already degraded, some use new ones. The BT ones I have take 108Ah so they must be new cells. But the other ones I just bought for $100 for my indoor chair surely aren't new... But still way better than lead. It's been a week since I installed them. Still at 26.5v. I can still get over my doorstep without having to gain momentum.
emilevirus
Postby Burgerman » 01 Sep 2025, 18:31
But they are either 1C or not 100Ah or are huge and wont fit. Anything longer than 260mm is no good.
And unless you have a good supplier you wont get decent A grade EV quality cells. The problem with this is that its super easy for any less than hinest seller to use B or worse, used, absed, warranty returned cells etc as theres thousands of them about. Because they last a long time and get dumped on the used markets when solar setups, EVs etc are upgraded. Its way too easy to sell a drop in lead brick replacment in a nice shiny smart looking "box" and get rid of them for huge £££.
I would be very very wary. If its cheap is it a problem? Yes. A BMS can work reasonably well on healthy matched low impedance and low self discharge cells. But used ones go out of balance. And a BMS isnt adequate to keep these degraded cells properly balanced.
Postby emilevirus » 01 Sep 2025, 19:15
Okay but at $100 though. A MK is what? $300 bucks? Will last about 5 years if you take care. A 100Ah LifePo4 in 10 years will have 80Ah capacity, which is still better than a brand new MK. Let's say BMS dies after 3 years. You can buy a new one and still cheaper than a MK. If you're savy enough, you can simply cut the battery open and replace the BMS.
No one should buy a lead in 2025 IMO.
Also, They make 100C lifepo4 now that can crank a V8 engine. Surely they can make a 3C group 24. Demand isn't there, probably.
emilevirus
Postby Burgerman » 01 Sep 2025, 20:42
MK? If you dont use it, leave it on standby float you get 10 years.
I used to get 9 months.
If you discharge it in an even smooth way, charge CORRECTLY and completely (16 hours) and never below the 80% discharge point you can get the caimed 500 cycles. Or 18 months.
However... If you use it in the real world, discharge in heavy pulses as we do, charge with crappy mobility chargers, and use it normally you get anything from 6 months to 2 years.
If you dont discharge it deeply, dont have mental heavy duty programming, and charge CORRECTLY you can get about 2 to 5 years.
If its hot where you live you kill it fast whatever you do.
I have 3 old packs here that were used daily for 10 to 15 years, still as good as new, only 3% capacity lost.
Because I charge correctly, dont take too much current, and dont over discharge them. The exact opposite that happens with a too small lead brick replacement LiFePO4.
If you charge and balance each cell to 3.550V and never discharge at high current, use a battery that is large enough capacity so that you pull low current per Ah and so never get much past 30 to 70 percent used, charge every few days to a week, then I suspect 30 years is quite possible. Even if a battery ever deteriorates by 20% so that say a 244Ah pack, has only 80% remaining, it will STILL go 80 miles instead of 100.... Like you will care!
On the other hand, things that LiFepo4 hates...
1. High discharge currents. Its proportional to lifespan. So a small battery suffers WAY more than a large one here. This on lithium is the No 1 killer.
2. Charging it at, an elevated voltage above the 100% full point causes damage. Makes cells gas and swell, and go high resistance.
3. HOLDING the full cells at this elevated voltage while a weedy balancer balances the pack during charge. So BMS directly cause damage here. Because they pulse, balance, pulse, balance over and over...
4. remaining on charge (i) after all cells are charged too long at this elevated voltage, and (ii) cutting off too early during charge before all cells are balanced...
5. heat
6. chrging daily (eats up cycle life, and lithium hates being full!) because small pack.
7. discharging by a lot daily. Big pack? You cant. Maybe charge every 3 days? So the battery spends most of its time between 30 and 80% full where it likes to be.
So with a BMS that cant control the charger termination time, cell balance time, etc and with small cells, you will see much more rapid degradation.
If the BMS is the problem. The real issue is that a too small cells, that are heavily used will not last long and a BMS makes that worse.
Several things here.
They used to make higher C rate LiFePO4 commonly in the beginning. But heres how it works. If a cell (or say a complete drop in GRP 24 battery) has a fixed maximum size then in order to fit 100Ah into that case you need low C cells. Why? Because high C ones require a thicker heavier aluminium foils internally or thy cannot take the current....
I have been using lipo batts since 98 in hobby stuff. On my shelf I have a lot of 6S liPo packs. Some are 10C and used for low powered low current power in powered gliders. We use the LOW C on purpose here because for a given battery volume and weight we get more Ah. Same thing in a quadcopter. Low C ratings = longer flight times. In stuff that eats power such as a 3D heli, where we want the same tiny batt volume/weight battery to cope with 100A or more we use 70C or 100C or 130C packs. But these neccassarily have LESS AH in the same volume.
So to make a GRP24 size LiFePO4 pack thats only 260mm long 168mm wide and 210mm tall, AND fit a BMS inside of that plastic casing requires low C cells. If you wanted to make that with 3C cells, or 10C cells, they will not fit into that casing! And so you end up with a smaller capacity. Lets say they can only fit 70Ah if its 2C or 50Ah if its 3C and of course now they need a bulkier BMS as well... And so to sell batteries they fit 100Ah ones... Then a BMS that allows 300A for a few seconds. Now the battery sufferes and that 10 years is just a dream... Might get a week or a year.
Postby Burgerman » 01 Sep 2025, 20:58
Then theres the C rating itself.
Hobby users want LIGHT WEIGHT.
And they want Ah (Mah actually).
And they want C rate!!!
Since theres no recognised C rate standards, any manufacturer can claim whatever they want. So they do...
All these C rate claims are massively overhyped. A 20C, or 50C LiPo and a 130C LiPo may all in fact be the same pack with different labels. How do we tell then?
If a battery has a weight or size that looks suspitiously low/small for its claimed C rate, its likely bullshit...
So we look carefull at the VOLUME (multiply the LxWxH in mm) or the weight. And the MEASURED Ah. Not the claimed one...
And we know that with a LiPo batery the energy density (Ah per cubic Centimeter) of a very high C rate battery is about half of that of a low 10C battery... So we can see a realistic expectation.
Same applies to LiFePO4...
So GRP 24 CASE? 100Ah? BMS inside? That will be 1C max sir!
And that rated 5000 cycles, 10 year life, is not the BMS equipped pack, but the O.2C discharge to 80%, 0.1C charge rate, of a single cell down to 80% of original capacity.
Postby emilevirus » 02 Sep 2025, 00:07
9 months! That's pretty much what I used to get as well. My cheapo BT 100ah lifepo4 packs have 1 year now. Still getting 109ah out of them for half the price of a MK. Worst case scenario BMS dies in a few months... I can order new ones and still be under the price of a MK because I'd have already replaced them by now. Best case scenario they last 5 years or 10 or 20.
Also according to the internet, using a 1C cell as 2C will cause 10-30% more degradation which means in 10 years will have about 60% capacity rather than the theorical 80%. That's still more than what you get with a MK. So IMO just need to be careful what pack & BMS you buy. So for cheaper, you get about 100% better range, faster charging, no worries about storing/maintaining the battery. I can't think of a single thing why I'd use a lead brick ever again.
emilevirus
Users browsing this forum: LROBBINS and 568 guests
