snaker wrote: Can you have a look to check if there is any parameter I should adjust.
@ I want it cut off sooner e.g at 3.000V (instead of 2.700V)
Williamclark77 wrote: I start balance at 3.45, OVP at 3.55, and OVPR at 3.5. .
After 1 hour, all cells are balanced at 3.400V.
Burgerman wrote:After 1 hour, all cells are balanced at 3.400V.
You must have balance start above 3.45V minimum. And hold voltage above this until balance ends. Thats the part BMS cant do. And unless the battery is held at 3.450 to 3.600V (3.550 best) then the cells will never be properly balanced. How do you balance a difference in v that keeps dissapearing?
A BMS stops charging when it sees the "charged" voltage, but then tries to keep on balancing as the voltage falls away again. But the difference in cell volts dissapears so it cant.
Williamclark77 wrote:I just updated my app and now things are moved around a bit and labelled differently. I would prefer to be able to set it to balance at 3.55v for XX amount of time then just shut off completely instead of turning current back on once one cell drops below 3.45 (or whatever your start balance voltage is set to).
Basically if you permanently mounted a PL8 to the pack.
snaker wrote:BMS cannot deeply balance cells as it has no control to proportionally reduce the charge current to a very low value (e.g 100mAh). But this balancing is already good enough. I think the difference between cells (if any) is less than 1Ah. That's very small (comparing to 314Ah) and no need to bother
Williamclark77 wrote:Did you figure out why it was going down to 3.4v?
Maybe CV of charger is too high after he reset OVP down (3.620→3.545). That renders the BMS cutoff it directly, leaving no time for absorption , when it was charging at 50A.
I set CV @28.45V, so current will fall gradually when approaching this voltage.
snaker wrote: I only see it turned the charge current on/off only 1 time during charging. It's fairly strange but that's good. Maybe, that's due to the dump charger I am using is a little special. .
Some charger may not restart when it saw high volt (battery is full)
Most E-bike users here prefer charging lithium with PSU.
Users browsing this forum: emilevirus, snaker, Yennek and 430 guests
