If it's decelerating why are brakes already applied? You mean it's still decelerating when brakes are applied?
The brake is NEVER applied unless the joystick is CENTRAL, and the motors are no longer turning.
No, nothing starts, it waits 2s then remove brakes and starts normally.
It goes like this:
You release joystick
It decelerates
So you are still moving? NO BRAKES ARE APPLIED.
So you actually STOP? Brake then applied. A brake is not used to slow a chair.
You push the joystick again
You hear the click so it's DONE decelerating. IT cannot be decelerating. Brakes are on!
Then it waits 2s and removes the brake and starts moving.
Well if the brake is on. The joystick must be central. And the chair has to be stopped. If you now move the joystick the brake will instantly release.
Or I am going to need to see a video.
Stupid question: could I install a different electric brake from another chair?
Since the brake is applied BY THE CONTROLLER and released by the same controller what possible difference do you think that will have?
Understand this.
A brake DOES NOT SLOW A CHAIR. It can/WILL only apply a brake if the following 2 things are true.
!. CHAIR STATIONARY. This is determined by motor voltage. ***
2. JOYSTICK CENTRAL.
*** IF rolling and your joystick is central then it sees the motor generated voltage. The compensation sees this and will add opposite "power" if set high enough. That then results in the chair stopping rolling, and THEN the brake is applied. The same happens on a ramp. Or if you RELEASE the joystick while rolling at speed. The system sees a centralised joystick and wants to apply the brake. It CANNOT do so until it also sees zero volts on the motors. So it will slow down, and as you wait it will eventually stop and THEN the brake goes on. This can be delayed on a ramp as the chair doesent naturally come to a stop so no zero volts situation happens. But compensation forces it to stop, and so THEN you get a click. Remember that just because the chair has stopped there may be 1 or 2 volts still at the motors as compensation is holding the chair against some movement from the casters or the ramp etc.
It's not a hardware issue. Looks like a protection or something. It's just voltage being applied to the coil. There can't be any delay here.
emilevirus
There isnt.
There can be a delay in APLYING THE BRAKE after you stop. A brake will not be applied while moving or if it sees a voltage. Those can be different things. Remember there can be voltage holding you stationary during this time if a caster is pushing sideways or a ramp or something is loading a motor.
Theres NEVER a delay RELEASING the brake if you apply power (move the joystick away from centre.)
If you think there is I am going to need a video of the joystick moved away from centre and a 2 second wait... That makes zero sense.
