Postby Burgerman » 06 Aug 2010, 19:15
I started doing a page here http://www.wheelchairdriver.com/powerchair-parts.htm
But kept getting sidetracked. So will link that page to this topic here.
So feel free to add links here. And to update and delete as needed.
Pride (overpriced) parts here in the US (Full parts and prices catalogue) http://www.southwestmedical.com/replace ... -mobility/
Sunrise (in the UK - There are others in other countries) http://parts.sunrisemedical.eu/uk/login/login.php use guest, guest for login/pass.
Give each post a new title so these links can be searched. And I will make this a sticky. :mrgreen:
Batteries
Postby segreen » 06 Aug 2010, 22:16
Burgermans favourite batteries the Odyssey AGM PC1500DT. This supplier will sell to you VAT free on production of your VAT exemption declaration.
http://www.odysseybatteriesonline.co.uk ... ELA01500DT
segreen
Metals etc
Postby Burgerman » 06 Aug 2010, 22:32
Stainless Steel Nuts & Bolts
Postby segreen » 06 Aug 2010, 23:09
Great store for nuts & bolts and happy to sell less VAT providing you supply VAT Exemption Declaration Certificate on delivery (UK residents only). I bought two full sets of A4 Marine grade stainless steel bolts for <£75
http://stores.ebay.co.uk/stainlessbolts
segreen
Groove 8mph motors
Postby Burgerman » 07 Aug 2010, 09:12
If you want Groove 8mph motors (rwd), these are the part numbers from Sunrise Medical (see post 1):
014827 MOTOR 13KPH SIDE B 06/08/10 1 £385.18
014828 MOTOR 13KPH SIDE A 06/08/10 1 £385.18
010383 HUB 2x £28.19
015261 MOTOR COVER KIT £6.02
2 "Q" CAPS&6 M4X10 SCRW
And 6mph latest F55s 4 pole motors are:
Brushes for 4 pole motors are 182132.30001 for one motor
10 kph 4 pole 182001.30002 RH
10 kph 4 pole 182001.30003 LH
10 sq mm cable for powerchair loom
Postby Burgerman » 08 Aug 2010, 10:20
www.kojaycat.com quality cable / wiring etc also has ebay shop. 10mm square cable for motors/loom etc
Bearings in stainless steel
Postby Burgerman » 10 Aug 2010, 19:11
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
Stainless bearing galore!
Standard powerchair and wheelchair bearings dont "wear out" they corrode. They get water in past the rubber seals due to hair etc and then fail. Stainless does not corrode. Powerchair manufacturers should fit these as stock.
I replaced every one of mine with stainless ones because the salt and crud that gets in from the roads dont kill them. Caster, caster fork, anti tip are all standard easy to get and cheap. Grease them all over when you fit them and they will come out as easily as they went in and still work fine 5 years down the line.
145/70 - 6 TYRES AND WHEELS
Postby Burgerman » 12 Aug 2010, 20:11
145/70 - 6 tyres ebay search...
Wheels, tyres and both together. This is where I get mine...
http://shop.ebay.co.uk/i.html?_nkw=145% ... m270.l1313
http://shop.ebay.com/?_from=R40&_trksid ... Categories
http://cgi.ebay.com/ebaymotors/145-70-6 ... ccessories
Some are 2 ply. Some are 4. Some are tubeless. Some are not. Tubes are available too. But at these low 4 to 8 psi pressures and the light footprints they seldome puncture anyway. I have tubes in one set and the rest are all 4 ply tubeless. But the pressures are so low that if you kick the side the tyre will deflate! So dont! Or use a tube.
3.00 x 4 tyres for casters, 9.5 inch diameter http://shop.ebay.co.uk/i.html?_nkw=3.00 ... m270.l1313
Roboteq
Postby Burgerman » 01 Oct 2010, 14:16
Stainless Bolts
Postby Burgerman » 02 Nov 2010, 17:56
http://www.westfieldfasteners.co.uk/A2_ ... sk_M8.html
Stainless bolts. New site. Looks to have everything we need here. In ones or as needed.
US Sources
Postby JoeC » 02 Nov 2010, 18:52
Various wheelchair components and seating: http://aftermarketgroup.com/
Dynamic Controls components: http://rosstron.com
Miscellaneous parts and materials (almost anything you can imagine, almost always in stock, and easily located): http://mcmaster.com
Least expensive source I have found for 4130 chromoly steel tubing, also carries aluminum, composites, and other materials: http://aircraftspruce.com/
A cheaper source of fasteners than McMaster Carr: http://www.boltdepot.com/
Wire, controllers, anderson connectors, battle tested: http://www.robotmarketplace.com/
Eurton Electric motor rebuilders- will rewind motors for higher speed or higher torque on request: http://store.eurtonelectric.com/wheelch ... epair.aspx
JoeC
Battery Meter - stand alone
Postby Burgerman » 03 Nov 2010, 17:51
http://motors.shop.ebay.com/lechi1993/m.html
Battery meters fuel gauge that work great! And on 12, 24, 36, 48v systems. Automatically adjusts. Can be programmed for AGM or Gel by the seller.
Re: Where to find everything powerchair related
Postby LROBBINS » 02 Dec 2010, 14:27
Good prices on Anderson connectors and DC circuit breakers:
http://www.scrubbercity.com/
Postby LROBBINS » 02 Dec 2010, 18:24
should have added in the above "DC-rated toggle switches"
Postby Lord Chatterley » 06 Dec 2010, 18:35
Copied to here from another thread to save Burgerman the effort-
Should anyone be keeping track or building something similar here's a list of bits so far and a stainless cap head (allen) bolt list. Most are dome or button headed bolts, some are countersunk, some normal "square" machine screws.
EACH CHAIR NEEDS:
ROBOTEQ 150 AMP NEW GENERATION CONTROLLER
3X PC 1200 ODYSSEY BATTERIES
16 ANDERSON 50 CONNECTORS
KART FRONT CASTER WHEELS (EBAY) OR STOCK F55 WHEELS
F55 FRAME FROM BREAKERS TO CHOP UP!
SEAT FRAME FROM BREAKERS ALSO TO CUT UP...
FABRICATED WHEEL ADAPTER / SPACERS
FABRICATED MOTOR MOUNTING BRACKETS
FABRICATED CENTRE SECTION
FABRICATED ALLOY BARS 20MM AND 15 MM
FABRICATED CENTRE SECTION MOUNTING PLATES
FABRICATED FOOTPLATE
FABRICATED FOOTPLATE MOUNTINGS
FABRICATED JOYSTICK POD (SEPARATE DETAILS)
FABRICATED SEAT MOUNTING PLATES
FABRICATED REAR LIGHT MOUNTING FOR F55 REAR LIGHT BINNACLE
BOLTS (STAINLESS STEEL) AS BELOW:
SET 3.00 X 4 CASTER WHEEL TYRES / TUBES
PAIR OFF ROAD 145/70 - 6 WHEELS AND TYRES FROM EBAY
QUICKIE GROOVE 8.5 MPH MOTORS
14 8MM ROSE JOINTS (MALE)
4X 44MM "GRIND" SKATEBOARD WHEELS FOR ANTI TIP
STAINLESS STEEL BEARINGS FOR CASTERS, AND CASTER FORKS AND REAR ANTI TIPS (14 TOTAL)
PAIR CASTER FORK (F55)
BASE - BOLTS ORDER: (for TWO powerchairs...) If you are doing 1, half this list!
MOTOR MOUNTS TO BATTERY BOX M8 X 12 BUTTON 16
WHEELS TO ADAPTERS M8 X 12 BUTTON 16
SEAT MOUNT PLATE TO FRAME M8 X 10 BUTTON 8
BATTERY BOX TO SEVERAL ITEMS M8 X 16 BUTTON 20
FRONT BARS TOP THROUGH ROSE JOINTS M8 X 25 BUTTON 4
FRONT BARS BOTTOM M8 X 16 BUTTON 4
FRONT BOTTOM BAR ALT M8 X 70 BUTTON
MOTOR WHEEL CENTRE CAPS M6 X SHORT BUTTON 4
MOTOR BRACKET TO MOTOR M6 X 35 BUTTON 16
MOTOR TO GB SCREWS M6 x 20 BUTTON 8
WHEEL ADAPTERS TO MOTORS M8 X 25 COUNTERSUNK 16
CROSS MOTOR ROSE JOINTS M8 X 90 NORMAL 4
FRAME TO BATTERY BOX M8 X 90 NORMAL 4
FRAME TO MOUNTING BLOCK FRONT
MOTOR END CAP BUTTON M4 X 10 BUTTON 12
cASTER AXLE BOLTS M6 X 16 COUNTERSUNK 8
This came to 22 uk pounds per chair (there are double the bolts I need as I am doing 2 chairs at once.)
From http://www.westfieldfasteners.co.uk
AND LATER WILL NEED THESE:
SEAT - BOLTS ORDER:
FOOTPLATE - BOLTS ORDER:
Lord Chatterley
Postby JoeC » 06 Dec 2010, 18:49
This isn't a powerchair part, but it's extremely helpful inside your home-
Offset hinges: http://www.amazon.com/Duro-Med-Expandab ... 614&sr=8-2
We have a pair of these on the bathroom door, and it adds at least an extra inch of width to the door when it's open. It's a little hard to get everything aligned so that the door still closes easily, but the extra inch makes a big difference on a daily basis.
JoeC
Postby TwoTeasChris » 08 Dec 2010, 18:46
Hyperion EOS1420iNET3
http://www.wheelchairdriver.com/board/viewtopic.php?f=2&t=456
The cheapest place I could find it on the net in the UK was from Robot Birds.
http://robotbirds.com/catalog/product_i ... ts_id=5832
159.52 Euros. That's £134.95 in real money. £141.45 inc. Recorded Special Delivery. (Came the day after the despatch-notification email.)
Does anyone know of anywhere cheaper in the UK? Because I'm getting another one. :mrgreen:
TwoTeasChris
P&G Progmamming s/w
Postby Martin O Refurbisher » 07 Jan 2011, 00:01
I bought my software from Robert Lee, mrmobility@consolidated.net, on Garry's recommendation.
It came with a 2m cable included (made by P&G UK!) which had the 3 pin Canon XLR / Neutrix plug on one end and a serial plug on the other.
Just plugged in, set the serial port to COM 1 in the s/w, and it worked!
I understand that you can also order the cable with a 4 pin scooter connector.
Best,
Martin
P&G programmer level C
Postby Martin O Refurbisher » 25 Jan 2011, 17:07
At the request of BM, reposted:
First, can I take this opportunity to thank Garry for finding Robert Lee - Mr. Mobility.
I bought my software and cable from Robert Lee, had a setup problem which he resolved by return e-mail (choice of com port), run it on a 10 year old IBM notebook via the serial port, and it does all that I expected. I can't offer a better recommendation.
e-mail him at mrmobility@consoildated .net
Note that there is the cable with the 3 pin Neutrix connector for our powerchairs, amd also another 4 pin one used for scooters. I paid $350.00 to him, and HMRC took some £41 in VAT & charges via the Post Office when it got here - I am awaiting the refund!
Best,
Martin
Postby Burgerman » 06 Feb 2011, 08:30
Goods imported by post into the UK
Tyres, motors, controllers, batteries, parts for adapted cars, electric beds, or anything related to your disability or mobility.
If the goods are being sent to you by post, ask the sender to write clearly on the package and its accompanying customs declaration:
'GOODS FOR DISABLED PEOPLE: RELIEF CLAIMED'
Or pay 20 percent extra, plus customs charges. ESPECIALLY if buying from the US... :shock:
44mm grind wheels (anti tips)
Postby Burgerman » 07 Feb 2011, 11:48
44mm grind wheels (anti tips) that I use are hard to find for some...
Anarchy Speedrocks Aggresive Inline Grind Wheels 44mm (Set of 4)
search
or http://www.streetlifeextremesports.co.u ... p-608.html
or http://www.rawk.com/product/anarchy-spe ... heels/532/
You also need set of stainless bearings (ebay) and stainless bolts (ebay or see elsewhere on this list) and some skate spacers!!!
Dont forget the bearing spacers! Any board/skate shop or ebay...
Postby Burgerman » 05 Mar 2011, 18:57
http://hegar4.com/zc/index.php?main_pag ... cts_id=255
Alloy Wheel halfs for the off road 145/70 6 tyres. They need to be 4.5 to 5 total rim width. These are available in a bunch of widths with or without valve holes.
http://hegar4.com/zc/index.php?main_pag ... cts_id=406
Tubeless kit for the rims... :mrgreen:
Postby Burgerman » 21 Mar 2011, 00:16
http://www.monsterscooterparts.com/alltires.html
Lots of tyres for the US. People keep asking me!
Postby nick » 11 May 2011, 13:08
Hello everyone
It's been a while since I posted but I did finish the chair and it worked great...but
It's improvement time!
Will fill in on the chair on my original post
So this post is about obtaining motors
We Just bought 2x 750 watt wheelchair motors off alibaba.com
http://www.alibaba.com/product-gs/233370660/ZHP_Series_Power_Wheel_Chair_Gear.html
Have only opened the box As have been home with the bloody flu
Tired me out just opening the box
They look good though
Hope to have a proper look this weekend
US $170 each plus shipping and payment costs
they only take telegraphic transfer which is a nuisance as T/T,s are a bit pricey
Approx $600 Australian delivered to my door all up for the pair of them
Came by air. I don't think they have sea freight
chair motors by nickluker2000, on Flickr
nick
Postby woodygb » 12 May 2011, 08:25
http://www.gongjidrive168.com/China/ZHP303.htm ..not a lot of data tho only dims.
Postby nick » 12 May 2011, 22:32
Well according to the sticker on the side its 700 Watts and 4600rpm
I have emailed Nina and asked for info about torque etc.
I wasnt that concerned about torque as its for my wifes chair so the designed payload is modest.
But power= Torque x RPM so if there 700 watts at 4600 rpm there should be good torque there as well
Untitled by nickluker2000, on Flickr
nick
Postby woodygb » 14 May 2011, 09:09
All the data you require appears to be there ..
The Ohms value is indeed in Mohms and they appear to have given values for their motor range 450 - 700 watts.
So... assuming the No Load motor current = 5.0 Amps and a 0.5 volt voltage drop for the voltage.
Watts=(RΩ/4)x(((rated_voltage-0.5)/RΩ)-No_Load_Current)^2
= (0.19/4)x ( ( 23.5/0.19) - 5 ) ^2
= 692 watts
Rpm per volt = 4600/24 = 191.66 from the data plate
or equation 4600/((24-0.5)-( 5 x 0.19)) = 204 rpm/volt
Stall current approx 120 amps
Motor Torque = 0.47 Nm/A
Peak efficiency close to 64%
There should be 4 wires ...two for the brake and two for the motor.
Postby Burgerman » 03 Jun 2011, 13:24
Headway Cells, BMS systems, Building blocks and bus bars, chargers, motors, and cheap Anderson connectors from Irene here http://www.evassemble.com/
Postby Burgerman » 04 Jun 2011, 12:18
http://www.chargingchargers.com/
Everything battery charger, battery info, and inverters related. GOOD information, many chargers for all eventualities.
Postby Neal » 08 Jun 2011, 23:35
http://shop.genuinedealz.com/
Good prices on marine grade cable plus possibly other items. (e.g. 3:1 adhesive lined heat shrink tubing)
Free shipping in U.S.A.
Neal
Users browsing this forum: LROBBINS and 231 guests
