Adding pulse pump to a generator
Postby Rye » 04 Apr 2025, 15:16
I had a small Honda inverter generator years ago that had a pulse pump and it allowed me to add a longer fuel intake line and just drop it in a fuel jug instead of having to fill the low capacity tank that was mounted on the genny. I recently bought a chinese knockoff, but it doesn't have a pulse pump.
Given there's enough clearance, can I just tap the valve cover and add a barbed nipple to run the pump? I think that's the crankcase ventilation hose already attached to the valve cover in the picture so I don't think that can be used. I'd rather not tap the crankcase
so I figured I can get the same pulse from the valve cover.
Rye
Re: Adding pulse pump to a generator
Postby Burgerman » 04 Apr 2025, 16:22
I would have thought the pulse came from the intake port.
If the crankase ventilation works well there shouldnt be much pulse.
Postby Rye » 04 Apr 2025, 18:00
Burgerman wrote:I would have thought the pulse came from the intake port.
The crankcase ventilation has a one way diaphragm built into the valve cover so I would think there should still be enough pulse to run the pump...in theory. I don't know because I've never done it. I could pop out that diaphragm and use the ventilation hose, but I don't know if the crankcase would get proper ventilation doing that.
I saw some guy bought a metal oil dipstick plug with a barbed nipple adapter which would be the best way to do it without damaging the small engine. However, I haven't been able to locate one. Another guy tapped the valve cover on a small pressure washer (although not as small as my genny) and seemed to be successful.
I think I've decided for test purposes, though, that I'm going to buy a PVC plug that fits the oil cap. Then drill it and install a 1/4" barb fitting. I don't know how well PVC holds up against oil, but this is just an experiment... I don't want or need to be lifting fuel cans so I'd like to get this rigged up.
I own a welding machine that has a pulse pump and that's how I fuel it. It's too big and inefficient to use when the power goes out though.
Rye
Postby Burgerman » 04 Apr 2025, 18:41
It wont. Crankase ventilation is there to remove any pulse, or it would pop out seals etc. Piston displaces the same CC as the engine in/out. The fact that it seems it has a diaphram would not allow it to work properly. So you may be mistaken and its just an oil trap - sometimes a larger volume, or a maze so oil drains back while the engines blow by gasses that pass the piston rings can escape without the oil. Or it would smoke and burn oil. If a breather is too small you will get a weak pulse. If its big enough to work well you will get a very weak pulse.
The carb has a diahram pump. That runs from the intake port pulses.
Return to Anything
Users browsing this forum: No registered users and 288 guests
