The Ducati was the only bike I had that could wheelie on demand,
Most of my bikes were double overhead cam, 16 valve 4 cylinder 1100cc 120 to 156bhp as stock. I never liked smaller bikes. All of them wheelied on power in low gears. Some did it in second. Second is about 100mph plus on a big superbike.
Once you turbocharge and / or nitrous inject them and do a few other mods then they wheelie in quite literally every gear. So to accelerate fast you need to drop the front, (fork legs through yokes) and reduce travel. On the rear you need a longer swing arm - amount depends on track.
Then they still wheelie like crazy in low gears and so you increase gearing so that 1st gear is good to around 90 to 100 and the reast are geared for around 200 because with a bug turbo, and say 25lb boost you are looking at 300 plus horseower at the back wheel. At the strip. On the street you set boost a bit lower like 17psi boost for reliability. That means you still get accidental wheelies in the first 4 gears. And up to around 14 to 150mph... Or you can smoke the tyre for about 1/4 of a mile insted. Depends if you hit it hard at low speed or wait for it to lift!
Anyway thats all a bit mentalist. The turbo bikes have silly power. But with a huge turbo you get a lot of lag. To get rid of ALL of the lag, you use nitrous. Around 45bhp worth, or 70 extra on the track, works unbelievable well. You get full boost instantly. Obvously its not actually instant, but the nitrous makes instant power before the boost then ramps up super fast because of the extra exhaust gas. It just feels like you lit the blue touch paper.
Anyway, theres a stock 1980s (1984?) VFR 750 on there. It isnt mine. It belonged to my freind when we were "touring" spain... It was good for about 155mph which wasnt bad for a little 750 in those days. See pictures. Its here.
https://www.wheelchairdriver.com/board/ ... 52#p203965That picture was my freind fotographing the clocks while I was alongside watching this happen at around 155. He did it no handed to hold the camera still. So it was slowing down rapidly on closed throttle as he did so.
Even so 152 mph approx on the clock in the early 80s from a stock 750 isnt too bad! It couldnt match my 1100cc bikes though. No the VFR 750 didnt wheelie well. Well at least HE didnt! It wasnt quite powerful enough to do it at every opportunity. Wheeliing was my party trick. I used to do it for miles on end in many gears. And out of lights, overtaking cars, etc. Learned while drag racing silly overpowered drag bikes and speed testing everything on a 2 mile runway while working for Performance Bikes Magazine. Loads of practice every week. Once learned, its easy. And hard not to just do it all the time! It just feels good at speed for long distances as you change gears accelerate and steer and pass cars etc.
