Ok I'll do this method.Burgerman wrote:If you are going to do that, then you may as well just use the PL8! Make up a lead, with an XLR on one end, and set it to 12A max. So you can charge the chair at a sensible speed as you drive.
Burgerman wrote:And they contain stupid problematic BMS (4 of them!)
Hi, I have mk gel battery, what care should I have to prolong your life ?
Burgerman wrote:You are not making any sense!
It doesent matter what charger you use, those are the charging requirements for the best service life.
Hi, I have mk gel battery, what care should I have to prolong your life ?, the pl8 charger serves to last me longer? while I'm buying, the Addon on
Users browsing this forum: Bing [Bot] and 312 guests
