R-Net PC Programmer OEM
Re: R-Net PC Programmer OEM
Postby Burgerman » 23 Jul 2018, 23:14
As far as I know, like pride its kept under lock and key. So nobody has and thats the issue. And why I said a lot of posts back that it would stop me ever buying permobil. Or pride for the same reason. No proper programming access possible.
The PERMOBIL version wont have that SUNRISE option, and all those settings. It will have the ICS menu items instead.
You may be able to see some of them in the OBP on the joystick. Because that too will be Permobil specific. But it will only show you some settings. Enable On Board Programming. Then look on the Joystick for limited ICS options instead.
Postby Rye » 23 Jul 2018, 23:21
I see MagicMobility chairs use Rnet. Do you know if this is an issue with the V6? I may be getting it toward the end of the year.
Rye
Postby Burgerman » 23 Jul 2018, 23:23
Not a problem as far as I know. Same as my chairs here.
Postby takenaback » 24 Jul 2018, 04:32
I have been kindly provided with the OEM R-net programmer but I was wondering if someone wouldn't mind supplying me with the Sunrise R-net OEM programmer.
Much appreciated
takenaback
Postby rover220 » 24 Jul 2018, 06:14
you can see come ics settings with dealer version but anything in depth needs the wheelchair builder software
Postby elryko1992 » 24 Jul 2018, 10:27
takenaback wrote:I have been kindly provided with the OEM R-net programmer but I was wondering if someone wouldn't mind supplying me with the Sunrise R-net OEM programmer.
Much appreciated
Check PM.
elryko1992
Postby takenaback » 29 Jul 2018, 02:15
Burgerman wrote:Another thing thats worth knowing. The sunrise version, and possibly other branded versions if we find them, have a good few extra tech setting options missing from the OEM version.
One example, the generic OEM has no option to set max output voltage to the motors. Default 21.6. The sunrise one allows a speed increase, if adjusted upwards to say 23.5V for lead, or 25.5V for lithium. Doesent sound much. But with the lack of voltage sag on lithium, makes a 6.2mph chair do about 7mph. And an 8mph chair do 9,3 according to my math. And expresso/snaker...
There must be another restriction as I put my voltage up to 23.5V from 21.6V and there was no speed increase.
takenaback
Postby Burgerman » 29 Jul 2018, 15:35
The speed can only increase IF THE BATTERY VOLTAGE IS HIGHER Than you chose.
If you use lead with relatively high impedance like MK gel or worse, the battery voltage can be anything from 26V to 20V depending on hills, gearing, state of charge, etc. Because as you load the battery its voltage drops.
Consider these two settings:
1. Setting it to say 20V when you have 25V at the battery allows 5V headroom for steering. (the outer wheel in a turn must SPEED UP and the inner one slow down) But the chair will be limited to 20V in straight lines.
2. Setting it to 30V means that at full speed you are using ALL the battery voltage (20 to 26) already. But the chair will go as fast as the battery will allow it to travel in straight lines.
So the actual effect this setting has depends on the actual battery voltage at the time, which varies due to, state of charge, battery capacity, internal restance, terrain, hills, peukert etc. So that it may or may not increase speed. Esp going up hill. If set high, you will be allowed to go faster downhil for eg. But it may have no affect uphill as the battery voltage falls below what you set/changed anyway.
Where it makes a massive difference is with high rate lifepo4 battery such as many of us use. Thats a solid 25.x volts, regardless of load, peukert, etc. So setting this voltage to 25V does increase speed even uphill.
Postby Wheels76 » 12 Sep 2018, 19:30
I have a dongle but I still need OEM software would anybody be able to send me a link?
Wheels76
Postby elryko1992 » 12 Sep 2018, 21:46
Wheels76 wrote:I have a dongle but I still need OEM software would anybody be able to send me a link?
Check PM mesaage.
elryko1992
Postby Colin » 05 Oct 2018, 09:35
Hi to you all !
Is anyone able to send me a link for the OEM RNET programmer ?
That would be nice !
thanks !
A french Guy :roll:
Colin
Postby Burgerman » 05 Oct 2018, 11:05
Heres the problem. THEY think that we are incapable of using an OEM programmer so they will not sell one to you. We are not "allowed". Even the dealers generally dont have them. So its extremely hard to buy. But if you buy a dealer version, theres a workaround that allows us to make the OEM work, and to finally get the chair to steer properly. PM me.
Postby rodgof » 29 Apr 2019, 08:54
can you pm with a link for update version of the R-net OEM Generic please
rodgof
Postby svhashemii » 15 May 2019, 07:47
wheels wrote:I have now managed to get a hold of the latest version of software "R-Net PC Programmer OEM", just message me and I'll share it with you, as I have the latest version. You will REQUIRE the usb dongle first though!
Hi Wheels,
Please Check PM!
Sincerely,
svhashemii
Postby svhashemii » 15 May 2019, 08:04
Could someone share the OEM R-net Programmer software with me?
svhashemii
Postby AlexD » 24 May 2019, 19:50
I have the dongle, but have lost my CD Rom with the software and need to install on a new laptop. Can someone DM the link? Thanks in advance
AlexD
Postby expresso » 24 May 2019, 22:21
i been trying to send you a PM with what you need but for some reason its not letting me attach it - i am sure someone here will get you what you need. either i am doing something wrong or its the site -
Postby steves1977uk » 24 May 2019, 23:43
AlexD wrote:Hi,
See PM. :thumbup:
expresso wrote:i been trying to send you a PM with what you need but for some reason its not letting me attach it - i am sure someone here will get you what you need. either i am doing something wrong or its the site -
expresso, you can't upload big files in a PM, you have to use online storage like dropbox, googledrive, etc... and share the link in the PM :) :thumbup:
Postby expresso » 24 May 2019, 23:53
i see - thanks - now i know
Postby AlexAGF » 20 Jun 2019, 08:18
I have a USB dongle.
Please tell me where I can download the OEM version of the software?
Thanks.
AlexAGF
Postby jjaco » 30 Jun 2019, 20:52
Hi everyone, I'm so happy to have found this discussion! I'm currently going through all this with my new Sunrise wheelchair and the CJSM2 joystick, and since there are some adjustments I'd like to make, I was looking for a way to program it myself.
Could someone point me out where to find an R-Net dongle, as well as the needed pc software?
Thank you so much!!
jjaco
Postby Burgerman » 30 Jun 2019, 21:08
See PM.
One way or another you need to buy a dongle. viewtopic.php?f=1&t=8525
Postby akrotkiv » 07 Jul 2019, 17:05
jjaco wrote:Hi everyone, I'm so happy to have found this discussion! I'm currently going through all this with my new Sunrise wheelchair and the CJSM2 joystick, and since there are some adjustments I'd like to make, I was looking for a way to program it myself.
Thank you so much!!
Hi all there, I am interested in R-net programming (dongle +oem sw) too.
Handicare (Quickie) Puma 40s gyro
akrotkiv
Postby Burgerman » 07 Jul 2019, 17:08
The software is easy. The dongle is not. You must buy one unfortunately.
Postby akrotkiv » 07 Jul 2019, 17:57
Burgerman wrote:The software is easy. The dongle is not. You must buy one unfortunately.
ok. please can you "hint" how to get SW, and where to find dongle for sale?
akrotkiv
Postby Burgerman » 07 Jul 2019, 19:45
Rover on this forum just sold a couple.
See PM.
Postby rover220 » 07 Jul 2019, 20:34
Burgerman wrote:Rover on this forum just sold a couple.
See PM.
all cleared out for now, wont be getting any more for the forseable
Postby presto » 16 Jul 2019, 02:22
Any chance you could connect me with the RNET software? Have the dongle but not the OEM software :)
presto
Postby rover220 » 16 Jul 2019, 16:10
check your pm
Postby BrightonGuy » 23 Jul 2019, 02:44
Is version 6.0.2 the latest R-Net_OEM_Generic software?
BrightonGuy
Users browsing this forum: acid_coke, Bing [Bot], jefferso, Mr.Math and 336 guests
