Videos - Rides
Re: Videos - Rides
Postby expresso » 18 Aug 2019, 15:33
thanks !! - i got one heated jacket but it was a lightweight jacket and really didnt do much -
i may try something else again - heated underwear long johns etc, - something that sit closer to my body - under clothes etc,
Re: Videos - Rides
Postby ex-Gooserider » 20 Aug 2019, 01:57
Take a look at the stuff made for motorcyclists and snowmobilers - there are a lot of choices ranging from vests to full coveralls with different levels of heat output and power consumption... Most run on 12VDC nominal, but that can be handled w/ a DC-DC if you get one with a high enough rating....
However it is also important to keep in mind the general concerns about any sort of heated garment and SCI or similar - if you don't have normal temperature sensation be extremely careful - detecting overheating by that wonderful BBQ aroma is not happy making when you are the BBQ.....
expresso wrote:thanks !! - i got one heated jacket but it was a lightweight jacket and really didnt do much -
Re: Videos - Rides
Postby expresso » 20 Aug 2019, 02:02
thanks i never gave that much though - i do have sensation and will feel it - the jacket i got was a simple wind breaker type and really dosnt do much when i used it - i liked the jacket so i use it without the heat on anyway - i feel it would work best when closer to the body
so heated Long Johns etc, under shirts - or the jacket has to sit very close tight to the body to feel the heat -
Re: Videos - Rides
Postby terry2 » 20 Aug 2019, 11:22
Mind The Gap wrote:
What camera and mount have you got?
It's very good. I may get myself one.
Hero 7 with a chest mount
Thanks.
That's out of my price range :D
Re: Videos - Rides
Postby Burgerman » 20 Aug 2019, 12:01
PPI :fencing
Re: Videos - Rides
Postby Scooterman » 20 Aug 2019, 16:03
"Have you had a accident in the past 3 years?" :fencing
Re: Videos - Rides
Postby Burgerman » 20 Aug 2019, 17:06
No. I did in the lst 23 though.
Re: Videos - Rides
Postby chazzyr » 20 Aug 2019, 19:05
chazzyr
Re: Videos - Rides
Postby Scooterman » 25 Aug 2019, 10:53
Nice :thumbup:
Rather a nice boat at the very beginning, I wouldn't mind owning that.
I went to windsor yesterday and took these photos. I have to hold my phone to film and it's a bit awkward, plus I'm very butterfingers. I suppose I could try rubber banding it to one of the wing mirrors?
As a side issue, it was a 30 mile round trip and on the main runs I averaged 9mph which I was pretty pleased about. It's cos I upped the motor from 24 volts for the littium, wish I'd done that when I first installed it.
Re: Videos - Rides
Postby Burgerman » 25 Aug 2019, 18:38
Every little helps.
Most of my powerchairs like the salsa, are almost the same as a stock chair. But a multitude of small changes (detail changes, programming, CG, seating and arm adjustments, wheels, tyres, 54 pole, 120A Etc) make the whole thing a totally different machine in use. Transforming it from useless to pretty good with a bunch of minor changes. Yet with a casual look and its almost stock. And as soon as my PPI checque hits the bank I will be ordering 210Ah lithium for it. So all the advantages below as well.
In your case the lithium has lightened it, so better on hills, and because of reduced voltage drop due to no peukert effect on lithium, and less amps drawn anyway (bevcause its lighter) your hill climbing abolity has improved. You are heating the motors less, and the two changes (peukert, less weight) compound each other. On a hill, your mildly modded scooter will now easily overtake a stock one going up a hill while heating its motors /controller less. The added voltage + tweak in programming has made it faster on the flat or downhill too. And increased the range (usability) by a large margin at the same time over a stock scooter while giving its motor a cooler running longer lasting life. So these things all compound each other and mean its really a different scooter.
Re: Videos - Rides
Postby Burgerman » 25 Aug 2019, 18:39
Every little helps.
Most of my powerchairs like the salsa, are almost the same as a stock chair. But a multitude of small changes (detail changes, programming, CG, seating and arm adjustments, wheels, tyres, 4 pole, 120A Etc) make the whole thing a totally different machine in use. Transforming it from useless to pretty good with a bunch of minor changes. Yet with a casual look and its almost stock. And as soon as my PPI checque hits the bank I will be ordering 210Ah lithium for it. So all the advantages below as well.
Re: Videos - Rides
Postby Scooterman » 29 Aug 2019, 19:48
Burgerman wrote:Every little helps.
They're nice cells, are they the new 105Ah Eve's curtesy of Shirley? That must be the most Ah that it's possible to squeeze in 2 x grp 24 space? Ignoring all the benefits of lithium and purely on a Ah for Ah basis, it's the equivalent of 6 x 70Ah lead batteries :dance. Then when you add the benefit of lithium it must be equivalent to even more :shock:
Went out today and saw a funny looking donkey with horns, and a nice looking motorbike :dirtbike
smartphone through binocs! :geek:
Re: Videos - Rides
Postby Burgerman » 29 Aug 2019, 20:06
No its not.
You can only get 35 to 40Ah AT THE VERY MOST from a 74Ah MK gel.
So you are actually going to need 74Ah MK x 2 for a real 40Ah before the chair stops.
So you will need 4 of them for 80Ah.
And 8 of them for 160Ah.
10 of them MK 74Ah lead bricks will get the same range as the 210Ah lithium cells. And what would that cost? And weigh?
Re: Videos - Rides
Postby Mind The Gap » 01 Sep 2019, 09:49
Hi all, Another video. Tough one this one, very hot day and loads of poxy kissing gates.
youtu.be/r_kS1QXHcyc
Mind The Gap
Re: Videos - Rides
Postby Scooterman » 01 Sep 2019, 21:45
I went for a road trip today, saw a squirrel sunbathing...
Re: Videos - Rides
Postby Burgerman » 01 Sep 2019, 22:45
That will still be there tomorrow... :clap
Re: Videos - Rides
Postby shirley_hkg » 02 Sep 2019, 02:37
Scooterman wrote:I went for a road trip today, saw a squirrel sunbathing...
drunk2
Are you sure it's not dead ? drunk2
Re: Videos - Rides
Postby Scooterman » 02 Sep 2019, 07:20
I think he’s probably having a rest. He’s probably tired out? :eh:
Or drunk2
Re: Videos - Rides
Postby Scooterman » 02 Sep 2019, 07:25
I just had a thought. Do squirrels hibernate?
Re: Videos - Rides
Postby Burgerman » 02 Sep 2019, 07:38
They are meant to. I feed mine daily throughout the winter.
Squirrels are not very bright. They just cant bear the thought of leaving nuts that are supposed to be gathered and 'squirreled' away. So every morning while there are still nuts, they just have to get up and hide, bury, store them away. They are at it even in a foot of snow and ice around my house non stop all winter. Even in january and feb... When the spring comes and it gets warmer they are confused, forgot to hibernate. They feel like fools I expect. The downside is hundreds of peanut trees start growing in the spring from pots, lawn, etc in all my /neibours gardens.
Re: Videos - Rides
Postby chazzyr » 13 Sep 2019, 01:26
Last Sunday I got the chance to ride on this catamaran, it was awesome! Below is the video I did.
youtu.be/_YJqWESfrsY
chazzyr
Re: Videos - Rides
Postby snaker » 13 Sep 2019, 02:16
Is it a river or sea? It looks like a river but too large. And the water is very clear. Where is all ... rubbish, I do not see it :thumbup:
Re: Videos - Rides
Postby chazzyr » 13 Sep 2019, 19:26
snaker wrote:Is it a river or sea? It looks like a river but too large. And the water is very clear. Where is all ... rubbish, I do not see it :thumbup:
It's the East River and the Hudson River.
chazzyr
Re: Videos - Rides
Postby Mind The Gap » 22 Sep 2019, 08:36
Hi All another video.
This is the first part of section 1 London Capital ring walk from the Woolwich foot tunnel to Baker road Woolwich. Part 2 to follow.
youtu.be/wBJ4N35APWE
Mind The Gap
Re: Videos - Rides
Postby Mind The Gap » 09 Oct 2019, 07:30
youtu.be/CYRfiVbce-M
Mind The Gap
Re: Videos - Rides
Postby rickystyx » 09 Oct 2019, 08:43
I do enjoy your videos - they inspire me to get out more.
Is that a gimbal on the left of the picture? if so do you find it isn't helpful?
Cheers
Ricky
ottobock b400 150Ah lifepo4
rickystyx
Re: Videos - Rides
Postby Mind The Gap » 09 Oct 2019, 09:52
rickystyx wrote:I do enjoy your videos - they inspire me to get out more.
Cheers
Ricky
hello Ricky Thanks. Gimbal not working to well due to being dropped a few times and Gopro picks up the gimbal motor noise. Was using separate audio capture device and syncing in post, very boring. Now wearing chest mount with no gimbal so no more audio syncing and just have to remember not to lean to the left to use arm rest.
Mind The Gap
Re: Videos - Rides
Postby Mind The Gap » 31 Oct 2019, 10:04
Beckenham place park, taking Bodhi for a walk.
youtu.be/kq76yadCaPE
Mind The Gap
Re: Videos - Rides
Postby foghornleghorn » 31 Oct 2019, 13:22
I didn't realise the golf course had gone. Driving through the park used to be like golf ball Russian roulette!
Re: Videos - Rides
Postby terry2 » 05 Nov 2019, 13:40
Just bought a Mova Mini S brans new from ebay for £40.
https://www.gudsen.com/moza-mini-s
Will try it out once it's fitted to my new chair :)
Users browsing this forum: Mr.Math, saker98, sergey0, shirley_hkg, Superchunk and 560 guests
