Burgerman wrote:Because its possible to set a thing that can damage brake, motor, or set a chair to run away, and break your legs with no way to stop it. So they think that OEM should only be for Original Equipment Manufacturer. Use.
woodygb wrote:Try this ..not 2 but should be very similar.
http://javafoundry.com/home/Q-Logic_Tec ... Manual.pdf
Standard manual.
https://www.quantumrehab.com/pdf/basic- ... %20boi.pdf
Burgerman wrote:No its a different manufacturers system.
Irving wrote:Actually on r-net you can have multiple joysticks. The master joystick is the one that powers on the system. The controlling joystick is the one with the earliest serial number. The deciding process is described, badly, in the R-Net technical manual. I've not tried it yet though.
rover220 wrote:No problem to have cjsm2 as attendant with an Omni. With correct programming you can have 2 master joysticks aswell. I have some experience of the glory headset.
Users browsing this forum: Juggler258 and 490 guests
