Yes it’s my problem that there are only very few settings shown. In the parameter file are much more. I think the other will need higher access level.
If thats REALLY a OEM level tool you have, then thats it. You dont have access and wont get access to anything better. Although I have seen Curtis instrument controllers with very in depth settings that went way further.
Its the new software 4402 that i have running. I also have 4401, but it is missing something, because it does not registrer the cable.
woodygb wrote:Here are some Otto Bock and EnAble50 files / manuals for downloading from my collection.
https://1drv.ms/u/s!AkMTZUw5KF1e5mKUTzq ... R?e=za89cg
NO....You will need the later 4402 software version.The profiles are .CPF files. Does Curtis Programming Station 4401 support them?
woodygb wrote:NO....You will need the later 4402 software version.The profiles are .CPF files. Does Curtis Programming Station 4401 support them?
Unfortunately the later 4402 software version is not ( TO MY KNOWLEDGE ) compatible with the A1+ Adapter.
Is there a possibility to increase the speed limit via software?
There are versions with 10km/h and 14km/h.
Mine is limited to 6km/h.
kaban
woodygb wrote:A genuine CANfox® is I believe the only solution for use with the later 4402 software.
https://www.sontheim-industrie-elektron ... es/canfox/
https://eltra-trade.com/products/ifm-electronic-ec2112
Users browsing this forum: shirley_hkg and 574 guests
