Postby SAPikachu » 02 Jan 2021, 02:50
Hi there,
Thank you so much for sharing information on wheelchairs. My wheelchair has the PG newVSI controller, I am not quite satisfy with its driving experience and I learned from this site that I can reprogram it to make it work better, so I would like to try it. I have ordered a TTL-232R-3V3 cable and now I need the OEM programming software to work with it. Can anyone send me instruction for getting the software? Thanks again!
SAPikachu
Postby Burgerman » 02 Jan 2021, 03:30
See PM.
Postby SAPikachu » 02 Jan 2021, 03:43
Got the links, thank you very much!
SAPikachu
Postby Yennek » 04 Jan 2021, 06:33
Looking for programming software for a newVSI controller. Helping out a friend who got a backup chair donated to him, but it is apparently set up something terrible.
Thanks in Advance! :)
(and, a RS-232 to TTL converter I built for programming radios 20 years ago will have a second life :) )
Yennek
Postby deswong » 10 Jan 2021, 10:26
Looking for the Dynamic Controls Wizard 5 software for a GBK52040 R-Series controller?
deswong
Postby Burgerman » 10 Jan 2021, 11:18
Well deswong, see pm.
Postby madmax08154711 » 27 Jan 2021, 13:36
Hi all,
I have a PG S Drive D51140.05 that I would like to programm, Can anyboady help me with the Software an the cable I need? Also it would be perfect if someone could provide a manuel for this controler with a pinout.
Thanks a lot
madmax08154711
Postby woodygb » 27 Jan 2021, 14:57
Check your messages
Postby Sashik77 » 12 Feb 2021, 22:31
Good day! Please help to find software for s drive OEM. I assembled the cable according to your plan and checked it on the dealer version, but it has very limited capabilities!
Sashik77
Postby niklas-k » 16 Feb 2021, 19:03
Hi!
I have a 2 DR90 controller and one of them i have to set parameter to be same to annother. I have installed Wizard 5 to my pc and building my own serial adapter found in this forum!
How do i activate the program so i can programming controller?
niklas-k
Postby woodygb » 16 Feb 2021, 19:17
UNINSTALL the genuine Wizard 5 ...Then install the modified / hacked version.
Postby niklas-k » 16 Feb 2021, 19:31
Many thanks!! :thumbup:
niklas-k
Postby woodygb » 16 Feb 2021, 19:31
Actually ...the order should go like this ..
Re-Install the genuine Wizard5... BUT DO NOT RUN IT.
Then install ALL the modified / Wizard 5 hacked versions files into the Wizard 5 folder.
Postby MarkFox » 03 Mar 2021, 17:27
Hi All,
I've got a Roma Sirocco power chair, with a newVSI 50 (labelled on the underside as D51161.01) controller which I'd like to reprogram to be less sluggish. I've got the USB cable + XLR plug on their way - would it be possible to get info on where to obtain the required software to handle the programming please?
Thanks in advance!
MarkFox
Postby woodygb » 03 Mar 2021, 18:06
Check your messages
Postby MarkFox » 05 Mar 2021, 13:36
Everything is working like a charm now, thanks! :)
Had to improvise a bit on the cable in the end - built a working replacement using an Arduino Uno + the 1N4148 diode recommended at the start of the thread which has worked great.
Feels like a whole new chair now, it reacts as quickly as I do with no lag. Any thoughts of replacing it are completely gone!
MarkFox
Postby Khreat » 16 Mar 2021, 12:27
Morning all. It's good to see the forum still thriving, as I've been away for a while.
I'm wondering if there is a way to remove an onboard battery charger in the programming? I cant find the option in the programmer or anything when searching here, although it may just be that I am not recognizing the appropriate terminology.
Any help would be grand.
edit, PG pilot plus system.
Khreat
Postby woodygb » 16 Mar 2021, 12:59
You probably need to alter an INHIBIT ( Inhibit 2 polarity) setting from HIGH to LOW .
MOST ( but not all ) onboard chargers inhibit HIGH ...whilst the standard off board charger inhibits LOW.
Postby Khreat » 16 Mar 2021, 13:56
Woodygb, you legend!
That cleans up the wiring and removes a water ingress issue I was worried about.
Thanks very much :thumbup:
Khreat
Postby woodygb » 16 Mar 2021, 13:58
You are welcome.
Postby peterik » 20 Mar 2021, 08:23
peterik
Postby woodygb » 20 Mar 2021, 12:07
NO.
You could use this as the basis for a programming cable.
https://www.fruugo.co.uk/ftdi-chip-usb- ... 3-30204646
Postby peterik » 21 Mar 2021, 07:27
I would buy a programming cable for Slovakia how much price?
peterik
Postby woodygb » 21 Mar 2021, 12:15
I can make one based on a cheap PL2303 chipset USB lead for £15 ...PLUS POSTAGE or a more expensive FTDI chipset USB lead for £25 ...PLUS POSTAGE.
Postby Burgerman » 21 Mar 2021, 12:25
Go with FTDI it works reliably... :fencing
Postby Frogeye » 27 Mar 2021, 08:54
I have a genuine PGDT serial to XLR cable ( and a steam driven laptop with a genuine serial port to boot :lol: )
I need to program a D50447.04 S-drive. I 'thought' I could connect to the charging port and program from there, but either I'm mistaken, or I have a fault.
I was thinking of making a molex to XLR adaptor ( I have the bits here) but I am unsure of correct pinouts, or if it would work. Would anyone be able to guide me please?
Frogeye
Postby woodygb » 27 Mar 2021, 09:10
Use the pic posted above in this thread as a guide.
Take pins 3 and 4 of the Molex and connect them both to pin 3 of the XLR Socket....pin 1 of the Molex goes to pin 3 of the XLR Socket.
I seem to remember that the GENUINE PGDT cable requires the 24V positive ...So pin 2 of the Molex to would go pin 1 of the XLR.
EDIT ...Is your 3 pin charging port actually connected to the S-Drives Molex?
Postby woodygb » 27 Mar 2021, 09:35
woodygb wrote:Use the pic posted above in this thread as a guide.
Take pins 3 and 4 of the Molex and connect them both to pin 3 of the XLR Socket....[u]pin 1 of the Molex goes to pin 3[/u] of the XLR Socket.
TSK WRONG!!! ...My mistake ...Pin 1 of Molex to Pin 2 of XLR
Postby Frogeye » 27 Mar 2021, 09:58
Hi Woody,
yes, the 2 pin XLR socket is connected to the 4 pin molex on the controller.
It's not a 'standard' mobility scooter! I'll post a couple of picture tomorrow ;)
Frogeye
Postby Frogeye » 27 Mar 2021, 10:03
looking at the picture above, and assuming +24v is required... wouldn't you be right with pin 1 molex to pin 2 xlr (GND) AND pin 2 molex to Pin 1 XLR (+24v)??
Frogeye
Users browsing this forum: acid_coke, duke1, jefferso, Superchunk and 321 guests
