in advanceBurgerman wrote:Dynamic DX2 or LiNX or PG Drives R-net?
COMPLETELY DIFFERENT!Brassick wrote:Can the PGDT software be used on the Curtis Instruements
model 1212-xxxx controllers? And infact are the S-Drive and the 1212 the same thing but built by different companies under license?
Thanks Nick
Darrell_LeRoy wrote:This is the first I have heard about an adapter. Looking at the adapter, there is no way to plug the USB to three-pin plug with the white wire with the diode and green wire connected to pin 3 and the black wire from the USB plug connected to Pin 2 of the 3 pin plug.
It looks like you need to have the adapter plugged into the USB port and a cable that goes from the 3 pin charging plug on the chair to the adapter. Is there a diagram that shows that cable?
...I think that you have just stripped back a USB extension lead.Looking at the adapter, there is no way to plug the USB to three-pin plug with the white wire with the diode and green wire connected to pin 3 and the black wire from the USB plug connected to Pin 2 of the 3 pin plug.
Darrell_LeRoy wrote:I did use a Schottky diode but I didn't put a 47K resistor in and have not connected the VCC line as it was not connected in several of the diagrams.
I have ordered the resistor and will add it to the circuit.
Users browsing this forum: acid_coke, duke1, emilevirus and 304 guests
