Burgerman wrote:Theres many types. What are you programming?
Darrell_LeRoy wrote:Why do I get this message and how can I bypass it and set acceleration higher?
11ydy wrote:Ask for help I encountered an unstable programming software connection after connecting some VR2 controllers to the computer. Where is the problem? It cannot be solved by replacing the resistor with a different resistance value.
https://youtu.be/W5CYuZFDoFI
[YouTube]https://youtu.be/W5CYuZFDoFI[/YouTube]
radredgreen wrote:I just got a used Pride Mobility Jazzy Jet with a PG Drives VSI Controller. It pulls badly to the right.
Use a multimeter and perform a continuity test between the Molex Pin 3&4 and Pin 3 of the charging socket..there is a green wire connected to pin 3 of the molex and I wondered where it is connected to.
Burgerman wrote:Its got different speed motors each side
Users browsing this forum: duke1, faico_26, jefferso, shirley_hkg and 563 guests
