LROBBINS wrote:Shirley,
It would be helpful to also have another FUIM3. !
Ciao,
Lenny
This FUMI3 USB serial converter looks trivial , but we cannot do without it, and is also very hard to find now .
Is it possible DIY ?![]()
Besides,
will these stock converters be a work around ?
Besides,
Thanks Woodygb.
Over the last week , I find dozens of used PL8 are on sale. However, it would still be useless for those late comers without a link to the CCS. Graphing is an essential feature .
I'm thinking of sending you a PL8, so you can put up something to replace FUMI3.
fishinjunky wrote: I was tempted to purchase this used pl8
https://www.ebay.com/itm/325120633919?m ... olid=10050
Burgerman wrote:The Fuim3 is opto isolated. Otherwise you can destroy your computer or the PL8 quite easily.
Burgerman wrote:The non opto isolated connection on the hyperion cost me a dead USB port, and 2 weeks later a dead motherboard. The PC chassis/negative/ground was at a different level to the motherboard. Worse, I knocked the connectig cable to the power supply while charging at 20A. That then caused the hyperion t connect its negative via the USB to the PC and its pos supply via the non isolated power supply pos. Which caused a small pop and the PC turned off. Indefinitely.
You must use isolated USB and/or power supplies. I mean really isolated. Even a little electrical noise means bad data.
Users browsing this forum: LROBBINS, Seafighter and 367 guests
