c500user wrote:Thanks woodygb!
I'll order the EC2112 CAN-USB and hope Curtis have not put some embedded code in the one they sold.
woodygb wrote:Please update me on the result.
woodygb wrote:Try with the earlier 4401 software.
I am also going to send you a registry hack that may or may not work.
it sets the access level from OEM to FACTORY!
c500user wrote:Last update for today.
I removed 1314-4402 and all Sontheim software from my desktop pc. I then ran ccleaner to get rid of old registry entries. Rebooted, ran ccleaner again to make sure all rubbish was indeed gone,
I installed 1314-4402 4.6.10. It installed without issues and showed OEM access. The EC2112 had NOT been plugged in and CANfox was not an available option in the communications section.
I then plugged the EC2112 in. Windows downloaded drivers automatically from windows update (took a few minutes).
The 1314-4402 sw was still running (showing OEM access). I changed the communication setting to CANfox (which option was now available) and saw the SW change the access level at the bottom of the screen to USER.
I exited 1314-4402, ran woodygb's hack and restarted the sw. Factory access.
I then connected to the EC2112 (timeout of course because nothing on the CAN bus) it stayed at factory. Unplugging the EC2112 and plugging it back in does not change this.
Could it be that certain data is only read from the EC2112 if the pc has been rebooted?
It is past 10pm here now, so enough for today.
Users browsing this forum: Bing [Bot], JazzyBand, snaker and 505 guests
