Office 2024
Office 2024
Postby Burgerman » 30 Jun 2024, 20:18
Re: Office 2024
Postby Burgerman » 01 Jul 2024, 08:21
And its shown here!
On all my rar files. And its always 123.
Re: Office 2024
Postby expresso » 04 Jul 2024, 02:18
Do you still have Adobe cracked ? can you share ? i like the one where i can edit forms - make changes to forms i have etc,
Re: Office 2024
Postby Burgerman » 04 Jul 2024, 08:24
Yep. And no crack needed.
You may need to block it in the firewall. But I find that its a thing of yesteryear. Firefof does everything you need to view. Word does a better job of editing or creating both pdf files and its own version of portable documents too.
I have it installed, dont use it.
I also have adobe premier, photoshop, raw, prelude, media encoder, after effects, illistrator, light room classic, all latest verions. All pre "cracked" and just ready to go. And these I do use...
Re: Office 2024
Postby Burgerman » 04 Jul 2024, 09:52
http://www.wheelchairdriver.com/doomed/
1.2GB.
Adobe Acrobat Pro 2024 latest. FOR 2 DAYS!!!
Just install, pre activated. Password 123...
I blocked it in the firewall. Block all the EXE files from outgoing. Just in case. Probably not needed.
If it ever tells you that its not registered or that its a bootleg version etc, then block it. Goes back to normal... It might not ever do that, I just block these things as a matter of course regardless.
Open rar file. Use Winrar.
Drag contents to your desktop. Run the obvious installer. Thats it. No crack needed.
Re: Office 2024
Postby agent86 » 04 Jul 2024, 13:43
I assume this is from a very trusted source without any malware inserted or is it user beware? Office 2024 would be appreciated back for 24 hours.
agent86
Re: Office 2024
Postby expresso » 04 Jul 2024, 16:13
will try it later
how do you block it as you say - in the past i used to get that asking to sign in - etc, or it wont work - it was an older version -
i just gave up on it then -
i try this one -
Re: Office 2024
Postby Burgerman » 04 Jul 2024, 16:44
I already did office 24 last week...
Will do it again after this.
Trusted source?
Me.
Tested to death. Its all safe.
How to block?
Your windows built in firewall...
Search for windows defender firewall... Then click:
ADAVANCED SETTINGS
OUTBOUND RULES
NEW RULE and follow simple instructions and navigate to the program files where you installed to and select the EXE file (or files).
Re: Office 2024
Postby Burgerman » 04 Jul 2024, 16:48
Anyone not grabbed Adobe Acrobat Pro yet?
Will do office again.. Takes 4 hours to upload!
Advice - not related but...
NEVER have or sign up to a microsoft account, a google account, an apple account, or any other advertising/marketing tracking company. Or utube, or any "cloud" nonsense or anything else that has any kind of advertising or tracking or other reason to have any of your details. Like chrome. And never buy software... Or use consumer based operating systems. And always use firefox with ublock origin and a good vpn.
Re: Office 2024
Postby expresso » 10 Jul 2024, 02:25
On some PDF Docs - i was not able to edit some items -
i wanted to change dates etc, years - but it was not editable
would some docs be done in a way where it cant be edited - built in etc,
Re: Office 2024
Postby Burgerman » 10 Jul 2024, 08:56
Dont know as I never found any that were not editable. If some of the stuff making up the PDF file is images rather than data feilds then nothing can edit them othr than photoshop as an image.
Re: Office 2024
Postby expresso » 10 Jul 2024, 22:49
i notice when i click - edit document - it highlights etc, the fields that i can edit -
but not all of them and the ones i wanted too edit - change a year and date etc, were not one of the highlighted fields -
i wonder if when it was made - its done in a way not to let anyone edit those fields
only explanation i can think of
Re: Office 2024
Postby Burgerman » 11 Jul 2024, 09:57
When you create a PDF file rather than a word document you do it because it is a finished or "cooked" end result that cannot easily be changed by a third party.
Unlike a word documment for e.g which is designed to be reopened and edited, a PDF document can have editable feilds or fixed elements.
For e.g when creating an order sheet with many multile choices with empty text feilds or tick box options in word, then as you save this those boxes and fields are saved as editable things in the PDF file. But the fixed text such as the questions isnt meant to be changable by the end user and the saved PDF file makes sure of this.
Think of it like your cameras photographs.
I shoot RAW files. Thats like a word document. It is just the bare basic sensor data. So you can change exposure levels and dynamic range, reduce noise independetly n each colour channel, and adjust things like sharpening properly. Then you save that as a final "cooked" product, your JPG file.
If you shoot JPG images then thats a final cooked end product that you cant change very much. Thats like the PDF file.
What I am saying is that a PDF isnt designed to be edited or used in the way you want to do. Although some basic editing is possible, it all depends on how it was constructed in the first place.
Dont save anything as a PDF you need to edit, only save the page, form or whatever when you ave finished it as a PDF. If you really need to edit it, do that on a word or watever document and resave as a final finished PDF.
Re: Office 2024
Postby Burgerman » 13 Jul 2024, 09:11
2 days left for Win 10 LTSC IoT good till 2032. The only good version of windows there is!
Pass 123
https://www.transfernow.net/en/manage/2 ... l/6qYz7QO6 click the download icon.
Re: Office 2024
Postby agent86 » 13 Jul 2024, 15:54
Burgerman wrote:Advice - not related but...
1. What email do you recommend or use?
2. What VPN do you recommend or use and do you run it on device or at the router?
3. Have you considered and encrypted privacy DNS as all websites and some email services are secure connection so the main thing I wan't is to stop ISP spying and reporting to government but not have the VPN speed issues. I get the VPN hides your IP from the website you are browsing but that is a less of a concern to me. That is when you use TOR browser.
agent86
Re: Office 2024
Postby Burgerman » 13 Jul 2024, 18:14
I use NORD VPN and it already has safe encrypted DNS and many other things all built in.
I use firefox, with the I DONT CARE ABOUT COOKIES and the essential uBlock Origin with my carefully configured feature and other annoyances personal list that I built up over years enabled in that too.
I have everything I dont want blocked in my hosts file, as well as in the built in firewall on Win 10 LTSC converted by the MAS crack to IoT with support till 2032.
Email?
NOT webmail. You have office, and you have Outlook. I use this with my own mail server. So anything@wheelchairdriver.com which I administrate works for me!
So for e.g. if you cant remember your email address, or someone else cant, then I_am_fucked_if_I_know@wheelchairdriver.com comes to me...
This way I control all spam filters, security, storage, encryption, max file size, and all the rest. And nobody can ever take it off me, change it, or whatever. And I dont have to worry about some other idiots data breaches.
And I have about 30 sites I use for free stuff... Inc movies, software etc. All ISPs block most of these by law due to copyright laws. So a VPN opens up the interweb and stops officials like the UKs internet harm bill etc from interfering or knowing anything. And it stops all the tracking companues like apple, google, microsoft, and 100s of others from tracking you. My google data file is completely empty. Most peoles is phone book thick for e.g. Download yours for a laugh.
Tor browser is too slow and tor exit nodes often blocked. For e.g on forums.
I can watch australian or american TV for e.g. You cant do that with a tor browser. Usually. Too slow and normally detected.
Return to Anything
Users browsing this forum: No registered users and 152 guests
