I charge through the XLR, leaving the chair on charge at 27.6V all the time barring a couple of times a week when in use.
But I do not understand the charging. When those batteries were new the chair would draw 10A for maybe up to a couple of minutes. At that time I guessed it was because of my usage, the voltage I set and the low capacity of the batteries.
These days it draws maybe up to 2A and reduces to no current in a couple of hours, or so says the display on the PSU. Something has changed, and I don't think it is my usage of once or twice a week, occasionally more or less.
Does the chair draw a chunk of current at intervals to maintain 27.6V? Or, as it is a cheap unit, will really low current display on the PSU as 00.00A?
Is this low current and short time because I am scarcely challenging the batteries with my usage?
When I get home after errands by chair I have a full row of battery indicator lights. The chair has had a sluggish feeling ever since I installed those batteries, more so than the AGMs. I try to ignore the sluggishness.
I on the other hand chopped my lead off a cheap charger many years ago and soldered a pair of banana plugs on.I use that at 40A silicone with the PL8!
I don't fold the Cirrus and didn't buy it for its foldability. I think the listing claimed it to be car transportable. Which it is - if the car is a WAV.
The Easyfold was BNIB at less than the price of a BNIB little indoor chair. I gave the battery little consideration. Or the dimensions, which are like a battleship but that's how wheelchairs are. The only good one I've used indoors where dimensions really matter is my Vienna granny chair and that is because it is shorter than the other indoor chairs.THIS has a very small footprint. But 55Ah batts, VR2 and has skinny tyres, narrow short base etc. A better compromise
Users browsing this forum: acid_coke and 331 guests
