no clue what thats all about. )biscuit wrote:<SNIP>
I shall test the voltage (and the resistance if my multimeter can do it), then equalise the pair and tomorrow during the day I'll run the cycle you suggest.
Thank you.
The ohm / resistance function on a standard meter is intended to work ONLY on things that do not have a voltage across them. If you put a meter set to that function on a voltage it will blow the measuring circuit!On the Easyfold the load is wired to battery C only, which is then wired to battery D. Does that make sense?
you can't change the world!returned some 5.5Ah to the batteries
The ZXD does not have a storage stage, does it?
.For waiting in the garage for me to go out riding on days with more degrees and less rain and lurgies. (Currently more than a week apart, those kind of days. Lincs. in winter is a beast.)
Users browsing this forum: Bing [Bot], LROBBINS, saker98 and 415 guests
