BCrip71 wrote:I am thinking of returning my Amylior R3 with a R-Trak. Has anyone ever used lithium batteries on a Quantum Rehab chair? Would charging at 10 Amps with a lithium battery charger, through the joystick, damage anything (joystick/modules/motors)? I asked Quantum and they do not recommend it.
emilevirus wrote:BCrip71 wrote:I am thinking of returning my Amylior R3 with a R-Trak. Has anyone ever used lithium batteries on a Quantum Rehab chair? Would charging at 10 Amps with a lithium battery charger, through the joystick, damage anything (joystick/modules/motors)? I asked Quantum and they do not recommend it.
I charge my 100ah lithium @ 12A using XLR port, no issue.
Burgerman wrote:Why?
Almost all the other manufacturers now either offer or supply 10A chargers or 12A such as Dietz etc..
They finally understood that the faster you get the fisrt part the bulk stage done then the better as it allows a longer CV or Absorption stage and gets you closer to a full carge in the overnight period we have. Without using too high voltage.
That means batteries last better...
Ignore them. 10 or 12A is fine.
Those batteries?
Are 8mOhm. Thats almost double that of the MK gel, (4.5) and 3x as much as the Odyssey at 2.5mOhms.
What does it mean? Well a heavy chair like mine, programmed to "go" will normally wheelie easily. With those, not a chance. But that just demonstrates the real ssue. They wont be great at high loads. So accurate control, tuning in place for e.g will mean the voltage drops a lot in comparison.
If climbing a hill for e.g then they will drop charge lights much faster than say the 3x better odyssey. This might not matter if its a slow chair, a light user, a chair programmed in what I call hovercraft mode, as you wont "feel" this as badly if at all.
They are the opposite to what you need for sport for e.g.
If you use it gently, dont have extreme programming they may be fine while new. Or new ish. But as battery ages its internal resistace goes up further... So they may run out of "torque" and range on say a hil, long before they lose much Ah.
Does this help?
Users browsing this forum: Bubbernator, emilevirus, snaker and 450 guests
