of lithium, would anyone know why this still happens today?
They only think about making money, right? The last thing they think about is wheelchair users, right? But I think they're pretty stupid Because if they did it with lithium they'd make even more money, right, friend?Burgerman wrote:Yes. The manufacturers do not understand lithium adequately. And they also do not make aything. They buy in standardised parts, like control systems, wheels, bearings, motors, bolts, lights, actuators, etc. Then they make a frame to hold all the parts and sell it as a powerchair. They are not exactly advanced!
Lithium isnt a battery. Its a part of a system. You need to consider the motors, control systems, charge systems, C rates, and so on as a single unit. That is designed to work together in the way an electric car is.
Not a bunch of seperate universal parts. That may work with 2 standard lead bricks, but lithium doesent work that way. So they try and buy lead bricks but "lithium versions" that are plug and play. And that works very badly for a bunch of reasons.
emilevirus wrote:But what about the new Permobil system? It now gives you the percentage and range left so it must have some kind of shunt inside the controller to calculate the draw and give you an estimated range/percentage. At this point, why not integrate a BMS and put Lithium batteries?
But yesterday there was a lot of snow and I managed to take 130Ah out of my battery. That's more than 3x of what the lead bricks could offer.
Burgerman wrote:But yesterday there was a lot of snow and I managed to take 130Ah out of my battery. That's more than 3x of what the lead bricks could offer.
Thats 130Ah from a 244Ah battery? in that case and thats 6x more than lead bricks.
Or more realistically 5x more with a FULL SET OF LEAD BRICKS RANGE REMAINING for safe return!
And I think that the X8 doesent even have Grp24? Doesent it use bigger GRP 27/31 batts?
If so then you can get 300 Ah plus in it. Maybe not I dont have one.
Why dont the manufacturers do that? See post above... They SHOULD and its lighter too which saves more battery power! That thing is heavy, has 4 motors and tortures batteries.
emilevirus wrote:Here they say "fitting lithium batteries may void your warranty" https://www.magicmobility.com.au/servic ... questions/
But let's take their Extreme X8 for example. It's designed to go offroad, in snow, etc. But yesterday there was a lot of snow and I managed to take 130Ah out of my battery. That's more than 3x of what the lead bricks could offer. So Lithium is a MUST for this kind of chair but apparently it voids your warranty.
You are absolutely right in this sense, considering that we are a grain of sand in the desert.Burgerman wrote:Because the AVERAGE user isnt on here. About 90% of disabled do a mile a day. Sit watching TV or drinking coffee or are say in an old folks home. And so they dont see the problem as a real problem. We are the odd ones. We are the problem. We dont fit the norm.
Add that to the way chairs are funded and bought. the vast majority are supplied to motability, a leasing charity in the UK or to the NHS and they do not ever have to compete in the world like the automitove and every other normal free market industry.
They dont need to keep making a better widget to sell their products. And they can charge whatever they want.
Tje lack of free market that drives inovation and pricing out in the real world of cars, lawnmowers, food, etc doesent really apply here. They are funded by that helicopter money and legislated and certified to death while the beurocratic bullshit decides what you will get.
Same reason they waited 10 years to get a used trabant 2 stroke or a moskacich car or a fridge in the state controlled socialist economy in the eastern block. Zero competitive market. Same reason that socialist everything, planed centrally controlled economies like venuzuala always fails.
If I made a perfect lithium wheelchair, it wouldnt sell. People in the US Canada, EU all get them "free" from insurace, the state, etc. And so you are not the one waving the cash. You are not the one they are trying to woo.
Burgerman wrote:Thats because 4 motors, big low pressure tyres, and crap loads of weight.
Basically 2 fat tyre power wheelchairs. Rolled into 1. But that means it really needs twice the battery as well. One of the other things that those things do that really hammers the battery and causes the flip flop steering to be worse is this...
You want to turn (or just correct your path) so you add some turn input. Remember that rolling along in a straight like takes the least power. So now it adds more to BOTH motors on the left and less to both motors on the right.
The motor load compensation now sees the currennt rise as it tries to turn. It is supposed to do so, as to turn you add a little more volts on the outer wheels. And a little less on the inner wheels. Which increases current further. But because the rear drive wheels are effetively trapped in a straight line and outer one cant/dont turn faster the motor load compensation adds a crap load of extra power to try and make them turn. Why? Because compensation is just a bit of electronics that measures Amps and is quite sensitive. And is a positive feedback loop based on current. When it sees the extra turn Amps it then ADDS MORE. It does this as the outer rear wheel cant turn faster of course . So the outer one doesent naturally speed up in response to the extra turn voltage applied. So the controller bumps up the power! Rinse and repeat. The front outer ones, that were already free to turn now gets an extra boost of power too that you didnt command as its wired in parallel with the rear wheels...
So the front gets the result of the compensation that was applied to try and make the rear drive wheels turn. But realistically they cant! And the extra voltage diference they now recieve adds more current because they just cant turn... So then it adds more! It does all this "adding" by increasing the volts. And so current. Which turns the front wheels beyond what you were wanting.
So the result is that it steers like crap. And eats battery trying to force the rear to steer.
So do you use lithium in your Estreme X-8?
Would it be too risky for me to put lithium in my Permobil F5 and charge it via the joystick with the original charger itself?
Burgerman wrote:29.2V will cook them long term... But its needed with a BMS as its overvoltage helps drag the low cells up and adds a degree of self balancing to make up for the crappy balance that the BMS allows. Again thats why I use a hobby charger at 3.55V per cell, without the continued bouncing on off/up down. So a solid continuous 28.4V with no cell ever exceeding 3.550V.
Marcelo wrote:Would it be too risky for me to put lithium in my Permobil F5 and charge it via the joystick with the original charger itself ?
I understand perfectly, burg man. In fact, I had already thought about that, right? Because charging at low amperages would take a long time, I completely agree with you on that. I would have to install an external charger, even in the 30 tamper range.Burgerman wrote:So do you use lithium in your Estreme X-8?
He uses 8 x 230Ah cells, a BMS, and an external charger.
If you were to do the same, then an 8Amp mobility charger isnt a great idea but it would work. But lets say you wanted to replace 230Ah... Actually 244Ah (measured) then at 8A it will take 30 hours, plus a couple of hours at CV and balancing. So about 32 hours.
This is why in my chairs I use a 40A charge, no BMS and a cell balancing charger.
But I suspect that you wont understand any of this due to the translation problem!
Burgerman wrote:I would be facsinated to know what they service. I never serviced a chair in my life. Nothing to service!
Only to repair it if it fails or breaks. Or replace its tyres, when worn out. Its not like its got oil or air filters, valve clearances, fluids to replace, etc.
So short of just looking at it to see if it works, doesent make any funny noises, what can they do? They can do that in 30 secs at your house. It is another way to use the system to charge the insurance or user for something. A scam.
Then drive till it breaks or fails or makes a strange noise or whatever. Nothing to service.
Burgerman wrote:Well it depends.
Are we taliking about fitting 8x 244Ah cells, and having all the benefits of lithium?
In which case a powerful BALANCING charger is best.
Or at 2nd best a BMS and a powerful dumb charger.
But if you are taliking about some lead brick drop in replacement batteries then those are only going to be around 70 to 100 ah or they wont fit. In which case you dont get a real long life, or much extra range. But then you can charge with an 8A mobility charger...
But that basically misses out on the very reasons that we fit lithium batteries. A long lifespan, huge range etc. And it may be unreliable because of higher C rate discharge, deeper cycling and a BMS that do unspeakable things!
So what are we talking about here by lithium?
emilevirus wrote:Well here we have winters and SALT. The frame just rusts like crazy after a few years. Same thing for cars. You won't see cars over 10 years old here unless they wash their car every ride which almost no one do. Wheelchairs are even worse because they use low quality metal/aluminum.
Burgerman wrote:Again it depends on a bunch of things.
If your chair is programmed agressively and you drive it like you stole it the typical lead brick keeps of tripping out as the BMS see intermittent high currents, or low cell voltage under load etc. And then we have get back home issues. We had a guy that dis all of that called nandol on here and he was repetedly rescued.
We also had a guy whose name I forget that had internal construction issues that made it keep tripping out. And I myself programmed a guys chair and that made it start acting up. Because now the chair actually responded! The battery couldnt.
So...
You may be lucky or not.
And it will likely be OK if the chair is programmed in grandma mode, or hovercraft mode as I call it, or if you are light, or if its a weedy controller of motors, or if its not a heavy rehab chair thats around 190kG withou a user. But dont count on ot being a reliable fix if you are several of the above.
But then I also blow fuses and make tripswitches pop too. But thats easy to fix with a heavier fuse. But the cells themselves dont like it either if like nandol you wire the chair to run direct from the cells and bypass the BMS. So it can work, it depends on a bunch of things. Inc the quality (internal resistance) of the cells used, the weights, programming, motor speed, controller capability, user mentality and expectation, BMS fitted, etc etc.
So as long as you understand that stuff, you may well be fine. But just dont count on it. Many tried. Some seem OK, some others not so much!
Users browsing this forum: No registered users and 484 guests
