The next function I would get is recline to give a chance to straighten and stretch out my upper body in addition to the tilt.
Burgerman wrote:Wouldnt a centre mount plate, with flip up footplate be a lot simpler?
Burgerman wrote:In the past I always have had a chair, usually an old ove kicking around WITH a lift that I seldom used. Why? Because its useful occasionally when you know you are going to need to get up somewhere higher.
For e.g. look at my rooM, in the pics below. Much stuff on high up shelves. If I know I am doing something (like today) where I know I will need to access those boxes or things on the high shelves I will use a chair with a lift. Same if I am trying to clean my van. Or attempting to reach stuff on shelves in the garage. Also if I am going to somewhere I miht want to take some pictures!
But a lift has a lot of bad consequences.
It makes the chair way heavier. The lift module alone weighs an absolute ton. Worse it sets up high, and raises the user up another inch even if lowered as far as it goes. This causes enough issues as it is for battery performance, stabiliy, caster shake likelyhood, reliability, and the feel of the chair. It also causes the chair to feel "flexible" and not solid and rigid. Even when down.
So MOST of the time I prefer to use a much lighter more nimble rigid feeling chair. Its just nicer to use.
Now if like me you have a bunch of chairs to choose from, then you will want a chair with lift. Preferably 300mm or more. For the times when its important. And chairs without for when you are busy and going places!
However theres some reasons why you may NEED lift all the time. For e.g if you have say dressing bench, sofa, bed all at different heights in order to transfer. Or in order to empty a legbag into a toilet. Personally I used to just go outside! But thats not always possible.
What about you?
Just out of curiosity, is there any kind of programmability on the lift speed, or is it a mechanical limitation of the motor in the actuator?
Burgerman wrote:Well you just summed up exactly what seat lifts are/do.
And showed why it isnt always a good idea to add stuff on the order form just because you can.
Weight lots!
Height adds a couple of inches.
Speed S L O W which is really frustrating.
Stability of chair worse.
Stability of seat worse!
Range and chair climbing performance worse.
But when you need it...
Like everything in life, its a compromise - a choice. Pros and cons.
I like to make sure I have at least 1 chair with a lift. When you need it you need it!
Burgerman wrote:And its got a control system that has no OEM level programmer you can get.
faico_26 wrote:Does anybody know if the Aviva (European version) really keeps 43,5cms height WITH seat lift?
Burgerman wrote:As I tell anyone that will listen...
I personally wouldnt even consider looking at any chair that wasnt programable, at the OEM (or Manufacturing) levels. By me, meaning I NEED to own the programming tools before buying a chair.
That sadly over time has resulted in only Full VR2 or R-Net systems. The rest are now all locked down one way or another or too old today. And so that rules out permobil too. And others like myra (some chairs) that both use own brand components as R-Net system components so cant be properly programmed in the normal way.
And these:
Always 4 pole.
Always rear drive.
Must allow seat to be relocated back far enough as all front drives are crazily nose heavy, ruining them.
120A power module.
GRP 24 batts.
If it doesent or cant match this short list above its ruled out of any possible consideration at stage 1.
All the rest of the 1000s of alternatives and tick box options that are possible do not matter.
Burgerman wrote:I have a lot of spares bought this way. Some of it here.
All joysticks new. Some of the power modules used but as good as new.
But to use it you need a programmer. And thats around 300. I have one obvously to match my 3 R-Net chairs.
Users browsing this forum: Burgerman, emilevirus, yeshelp and 546 guests
