Universal assembly fixtures
Postby Vitolds » 09 May 2025, 23:54
Hi. Tell me, does anyone know what such devices for machine tools are called in America?
Vitolds
Re: Universal assembly fixtures
Postby Burgerman » 11 May 2025, 17:50
Do not know.
Postby swalker » 14 May 2025, 03:34
Google machinist hold down clamps. You will see a variety of options going by a variety of names.
2024 Permobil F5 Corpus 3G
2016 Permobil F5 Corpus 3G
2014 Permobil C500s VS
2013 Permobil C500 Corpus 3G
swalker
Postby Vitolds » 14 May 2025, 13:35
the point is that no one sees or knows.
Vitolds
Postby LROBBINS » 14 May 2025, 13:42
Postby Vitolds » 14 May 2025, 19:30
these are clamps.
Vitolds
Postby Vitolds » 14 May 2025, 19:32
it's like lego for adults
Vitolds
Postby Williamclark77 » 29 May 2025, 17:03
In order on your first post:
Fixture plate (T-slot type)
Strap clamps
90 and 45 degree fixture plates (T-slot type)
T slots are typically 5/8" sized on American milling machines. That is the width of the slot the T shaped nut slides into and are threaded for a 1/2-13 bolt. They are available in hundreds of different configurations and different proprietary names from different manufacturers. I use them along with 123 blocks often.
123 blocks are precision ground fixtures that measure 1x2x3 inches. 456 blocks are also common. I don't use them because they're too heavy for me to use easily.
I would post some pictures I have taken of setups I have done but something is broken on the forum or my settings or permissions. I cannot embed photos. I get the attached error. I tried literally copying the example showing how and it gives the same error.
Williamclark77
Postby Vitolds » 30 May 2025, 17:23
Here's a video of what it looks like. It's convenient for assembling various universal matrices (for welding, drilling, milling).
I wanted to know if such devices are available in the US.
https://youtu.be/vfYJDvBcWe0?si=P9_dPUxbR_eDaZwB
Vitolds
Postby Williamclark77 » 02 Jun 2025, 15:41
They are very available here. Although, most cheaper versions are made in China. There are still some USA companies that make different fixtures. Quite expensive though.
There used to be many small machine shops here where you would see hundreds of different fixturing setups hanging up. Not as common now. There's just not as many.
Williamclark77
Postby Vitolds » 02 Jun 2025, 16:19
steel sheets 1.5mm, 3mm, 2mm for laser cutting is it possible to buy?
Vitolds
Postby Williamclark77 » 02 Jun 2025, 17:20
Yep. VERY common from many places. I use three different places that will sell small quantities to individuals within a 40 minute drive of my house, and I live farther from the city than anyone I know. We typically buy sheets in fractional sizes - 1/8, 1/4, 3/4 inch, etc and gauge sizes below 1/8 inch though. The most common standard length x width is 4x8 feet (48x96 inches). I just bought some, had it laser cut, and shipped to my house for cheaper than I could have machined it myself when you consider my time and tooling, not to mention the difficulty handling the material. Cutting out 2d flat parts is hard on tooling and slow with a CNC milling machine. I don't have a laser, plasma, or waterjet.
Metric sizes are available but not common - as far as I know.
Williamclark77
Postby Burgerman » 02 Jun 2025, 20:55
Well they are pretty much the most common sizes everywhere else in the world!
Postby slomobile » 30 Jun 2025, 21:40
What features differentiate a fixture plate from a "tombstone"? Tombstones as I understand it are rigid base plates that a workpiece is setup on outside of a busy mill. Several tombstones can be swapped into and out of the mill (either manually or automated) to achieve continuous production.
Was wondering if the cross feature on the ends in the first picture might be for repeatably aligning the tombstone onto a mating fixture bolted to the mill table.
slomobile
Postby Williamclark77 » 01 Jul 2025, 02:32
Nothing specifically sets them apart, at least that I'm aware of. We typically refer to one as a tombstone on a horizontal mill that multiple fixtures, parts, or setups are mounted to. We don't usually use the same types of setups on a vertical 3 axis mill since you can't easily reach anything but the top.
Nothing says this terminology is correct.
Williamclark77
Postby Vitolds » 02 Jul 2025, 14:19
you can turn on subtitles translation. from these blocks you can assemble a jig for drilling. i use it for welding different parts on the table
https://www.youtube.com/watch?v=tnZZnhQ6KoI
Vitolds
Return to Anything
Users browsing this forum: No registered users and 136 guests
