Are you referring to the back EMF generated by the spinning motor? As RPM ramps, the motor becomes a generator that opposes the input current. Was there something specific you think I need to know? Any guidance to chose motor size and gearing for the load? Or defining our load?
slomobile wrote:All have the same big 2-stage right-angle worm gearbox. I think I've heard these referred to as "Hammer motors".
Burgerman wrote:Answer me this question.
Do you know why it is that the battery current can be a quarter or less than the motor current? Or the same. Depending on RPMs?
Short of what?Burgerman wrote:Peak Current (5 sec) (Amps) 65.0
Peak Power (5 sec) (Watts) 714
S1 Current (Continuous) (Amps) 15.0
S1 Power (Continuous) (Watts) 253
Seems a long way short!
What will melt? Why?They will melt...
I also will use roboteq. 2 HDC2472 The exact configuration is still in flux.The roboteq for e.g I use
Ok. The motor amp reading is only estimated by the Roboteq controller, not measured and is not accurate at low speeds. According to the Roboteq sticky on this forum. Is that what you were trying to say? I really have no idea what is the FUNDAMENTAL thing you are trying to say. Is it just that it takes a lot of amps to turn in place? I get that. Are there any equations to estimate the required amps to turn in place for a theoretical chair design? If amps are exactly proportional to torque, this should be modelable. That would help me.needs 150A on its 8.5mph motors to have reliable turn in place torque, (Amps = torqe in exct proportion). I used the 150A per channel robteq because the same 8.5mph chair motors with a 120A controller (R-net were gutless).
Yes, understood.A turn in place in my hallway on carpet requires 116A on one motor and 112A on the other. Try that on a ramp or some uneven grass, or with turn acceleration turned up and it hesitates, doesent follow the stick properly and both motors are pinned at 120A due to the compensation trying to make them move.
Absolutely no idea what you are trying to say here. Seems a complete non-sequitur.And if you look at their CONTINUOUS ratings then at say 6mph its about what you will see. But you will be able to make a motor go 3x faster. And so on the flat, that will increase the full speed watts a lot, and it will increase the full speed current too. Above what your motors can handle as soon as they see a hill.
This seems to contradict your fundamental thing that I don't get apparently. Under what conditions are you speaking of here? On flat, on incline, accelerating, constant speed? At double the PWM width, or at double the battery volts, or double the motor volts, or EMF volts minus BEMF volts, measured across what 2 points? Max volts, RMS volts, average DMM volts integrated over what period? Are any of these the same thing? Why or why not? I think that might move us a bit further down the road. Doubling the voltage is a step change opposed by the coil in a permanent magnetic field. That opposition either motors the coil out of the way, or it heats the coil in a locked rotor situation. Which of these is fundamental?Remember that at double the volts, the motors dont only take double the watts, they take double the current as well. So 4x the watts! You climb the same hill in half the time.
So doubling the voltage increases power by 4x.
And you are not doubling it but increasing volts by around 3x. Because a loaded lead battery is under 12V. And that drop doesent happen to lithium.
Having not understood the previous part, don't understand why you limited the voltage. Other than the first part where you said it will melt, but not why. Will the motor insulation melt under locked rotor current? https://en.wikipedia.org/wiki/Insulation_system I think our motors are usually rated class F to 155C. Predicting temperature rise based on motor current relies on info I don't know how to apply currently. I may have known at some point and forgot. Is that the fundamental thing?This is why I limited the chairs battery to 13S. Not 16. And why I used motors that were desiigned to be used with the 120A R-net system, and then upped it by just 20% approx to 150A. So leaning on it a little but hopefully no too much.
I'm not using ElectroCraft motors. At least not yet. They look pretty good in some respects. I was thinking about it and looking at specs spread over many pages and thought it might be helpful to generalize and bring the motors with same gearbox but different motor types together in one thread to look at the differences between motor types. I'm using 4 Quantum (Linix) 2 pole motors in one 4wd experiment, Permobil motors on my 2 daily chairs, Jazzy 1450 motors on a plywood utility cart, Jet 4mph motors on a small yard bot, 2 Schwinn 24v kids ebike motors with #35 chain. I'm trying to figure it out.So the next question, really is the one that I asked originally. Why are you doing it?
My logic is not logical lately. Blockages in both carotid and both vertebral arteries and LAD. On the verge of a brainstem stroke. So in one respect maybe this is a waste of time. But its what I enjoy. Thank you for making it possible.My logic was...
I wanted a faster chair, so 8mph chair, and I tested many. ALL of them made inadequate torque for decent control. They didnt do where told. They all lacked torque due to the 120A limit.
Now a 6MPH chair has JUST enough torque on a 120A controller that I cant stall it out and it follows the stick 99% of the time.Similar here, but often running grassy hills where I am traction limited. Need slow controllable torque and ability to maintain momentum through obstacles. But I like to go fast when I can. Falling prey to the Pride marketing. Until recently I was able to walk away if I got stuck and that made a lot of dumb things possible. Not so much anymore. Having a lot of trouble lifting my arm to turn a wrench or screwdriver and projects are languishing.Is that the fundamental thing? Inadequate amps = poor response? Of course. That is why I chose the Roboteq with same 150A as you but higher voltage (72v). Only later finding out it was a much older model lacking features I want. Oops.See here:
100A controller on old light 6mph chair. This is CLAMP current meter over 1 extended motor cable. Even turning alone maxed it out. That made it hesitate and not respond as it should. The joystick felt non-ninear. So a 100A power module was not adequate on a 6mph chair. It ALMOST is!
http://www.wheelchairdriver.com/doomed/motoramps.mp4
Watch it sit at 101A at the end, the slowed down video. I try to turn. It initially fails. Non linear response due to inadequate current!That all assumes you are using the same motors. Not all motors can handle the doubled voltage. Larger diameter motors do more torque and less speed with same voltage and current, but are heavier and larger. If doubling voltage, why not get a really large diameter(close to wheel diameter) but thin motor without bevel gear to get a little better torque and speed in a single stage gearbox rather than double to offset the weight disadvantage. Thus the axial flux PMDC and radial flux PMSM possibilities natively rated for the higher voltage and current so no concerns of melting.So in order to get double the speed, you need double the voltage, and the SAME slow motors. (because taller gearing needs more Amps at the same load...
And at the same current you now get:
Same torque as before (voltage has no affect on stall torque).
Double the speed, due to motors turning at 2x rpm per volt in proportion.
Volts = RPM (speed)
Torque = Amps in exact and direct proportion at STALL provided the motor impedance allows it to draw the maximim current the controller allows.Was that the fundamental thing? Maybe show us the quick maths so we know how to make that decision for other motors.So some quick maths told me the 8.5mph motors with lithium, and with a 150A roboteq controller was going to give ALMOST as much torque as the 6MPH ones albeit at a higher current.
And that the 45V when programmed with no steer headroom unlike a mobility controller that limits this to 21.x volts typically would give me 16mph.
And it does exactly that.So thats why I asked what you were trying to achieve and why 16S and was interested in your logic?
Short of what?
That's actually is true for MotorAmps and BatteryAmps - they are not in the same circuit. BatteryAmps is controller input, MotorAmps is controller output, though it may be be estimated as (BatteryAmps/fraction PWM).You probably learned that the CURRENT is the same everywhere in a circuit. Well in the case of a motor controller that's absolutely wrong!
Users browsing this forum: No registered users and 282 guests
