shirley_hkg wrote:BM's 120 tyre is 45mm offset, from mounting face to barrel end of adaptor.
Instead, this is the offset of a narrower 3.50-8 tubeless tyre and rims, that most people use.
sparkerted wrote:Yes. I suppose I aught to contact Amy and order some cells
Heres the LITHIUM measurements:
With digital micrometer.
53.77 thick at edge, cant measure centre... Looks super flat.
73.88 wide and flat.
204.62 to flat top face
16.22 termital heght from to face of cell.
220.84 total tall with thread terminal height
From: GYWHEELCHAIRS (NORTHERN LINCOLNSHIRE AND GOOLE NHS FOUNDATION TRUST)
Sent: Monday, June 3, 2024 10:04 AM
Subject: RE: Personal Wheelchair Budget
Good Morning John,
Please see document attached. Can you please confirm that you approve of the specification in the document attached so that Louise can then get the rep to generate a quote.
REPLY
The thing you attached is basically a TWO of lines of text. Its not an order form.
An Order form, or a prescription order form, looks like the one that I have attached ON THE REPLY as an example. I have ordered many chairs, and can accurately fill out a real order form and know exactly what I need/want.
In this case the example one I have attached its for sunrise Q 500 chair.
THAT is a proper order form.
If you want to get the order right, since you seem to have forgotten the two separate, 2 hour long sessions with you and the various company reps, (which was the entire point of them being there) with all the questions and detailed answers we already did. Complete with my own printed data sheet I handed you, then lets strt again and bring a proper order form around for the Dietz chair so that I can go through it in detail and fill it in correctly.
Or if you are going to attempt to make all these decisions yourselves, then it will be your problem when its incorrect.
though less so with my reprogramming it along your preferred lines - I found it much improved but in retrospect I should have started off by limiting the max speed to a steady walk until she got used to it, as her hand control is poor and tends towards On or Off!
shirley_hkg wrote:https://youtu.be/hc2K9ZP-UP0?si=rU-nzxCyGB5WFYQ-
Same thing happened to friend's Dietz.
I'd blame the design of this swing away mechanism. It wiggles the cable 180 degrees at 2 spots, every time you set joystick aside.
Old fashion quad link design seems don't have this issue.
Users browsing this forum: Seafighter, shirley_hkg, tettralytic and 344 guests
