Scooterman wrote:I remember trying to crimp the thick walled anderson pins. Couldn't do it, they just wouldn't squeeze down sufficiently.
Re cable sizing, I was looking at the stranded copper pvc cable that Sunrise use for the power connector on 120A r-net. And it says it's 10awg. I was originally going to use 8awg silicone for the links (which are very short). But if the r-net power lead is only 10awg (and a longer cable) then I can't see the point of using 8awg silicone.
But the 10awg Sunrise use for the power doesn't seem very thick considering I think BM has said r-net can deliver 120A per channel. So theoretically controller could draw 240A from the batteries? But I'm dubious whether the controller spade terminals could carry that current for long.
IMHO it's usually connections/terminals that fail (burn) under excess load rather than the cable insulation itself melting. Although I have seen this happen with an extension lead where the person didn't fully unwind the lead before plugging in a 3kw electric fire.
Burgerman wrote:Scooterman wrote:I remember trying to crimp the thick walled anderson pins. Couldn't do it, they just wouldn't squeeze down sufficiently.
Wrong size cable or weak crimper...
LROBBINS wrote:If you put that fuse in an SB50 & mount another SB50 connected to the battery in an easy to reach place, it can serve as a disconnect link when, for example, traveling by airline or wanting to work on the chair with assurance that power is disconnected.
Users browsing this forum: acid_coke, Burgerman, fishinjunky, LROBBINS, tettralytic and 491 guests
