by Burgerman » 11 Jun 2025, 16:35
I mean that...
If the chair was previously fuuly charged, and as sat for 2 weeks then its now at 99% ish. Does that mattery? Yes. Because that 1% missing is 1% of the capacity that is now lead sulfate coating the plates. If you leave it that way it turns to larger xstals, that dont conduct so will forever stay that way. And your battery now has 1% less Ah.
So That this doesent happen, and so this doesent end up at 2%, 20% or worse, we need to return that sulfate back to the electrolyte where it came from while its possible.
Since the battery is nearly full, a high rate recharge that wwe use in cyclic daily operation isnt required. Just 16 to 20 hours at a high float level such as 13.6V. Or 27.2 for a pair.
With the XXD thats easy. Just set it to POWER SUPPLY and choose 27.2V. Start it, go to bed. Take it off in the morning. Or dinner. Not critical.
No elevated "fast charge" at a higher voltage is needed.
Or set to LEAD CHARGE, and choose 27.2V. And choose say 0.4A, and then float at 27.0V. Set 5 hours float. And Auto off.
