No PL8 No Charging?
No PL8 No Charging?
Postby saker98 » 19 Oct 2025, 10:37
I currently have a 8 x 105ah cell pack and a to be built 8 x 230ah cell pack.
My PL8 does not work(it died!)
Is there a working alternative balance charger I can use with Shirley's new ZXD2400 TFT 3.2" charger or another way of charging them.
Thanking all in advance :worship cheers
James
‘If you are NOT in control, leave the STRESS to them”
saker98
Re: No PL8 No Charging?
Postby shirley_hkg » 19 Oct 2025, 13:10
https://www.wheelchairdriver.com/board/ ... 56#p210956
JK active balance (0.4A--2A) BMS, programmable and BT connectivity.
I can find decent PL8 (used).
Postby emilevirus » 19 Oct 2025, 14:44
Or Junsi iCharger works fine too.
emilevirus
Postby saker98 » 19 Oct 2025, 15:12
shirley_hkg wrote:https://www.wheelchairdriver.com/board/viewtopic.php?f=2&t=12583&p=210956#p210956
Hi Shirley,
I have a Victron 24v 12A with a Neutrik XLR connector.
Also Victron 12v 30A with a SB50 Anderson connector.
Plus a Victron Shunt.
I am looking for a long term charging system with Balancing.
Thank you
Saker98
saker98
Postby saker98 » 19 Oct 2025, 15:33
emilevirus wrote:Or Junsi iCharger works fine too.
There seems to be a few Junsi iChargers with a heavy price tag.
Could you suggest one that might work?
regards
Saker98
saker98
Postby Burgerman » 19 Oct 2025, 15:37
Any that can do 8S or greater. The more power the better as you are charging a large battery.
Postby shirley_hkg » 19 Oct 2025, 15:50
ZXD2400 plus a programmable BMS are pretty good, or Victron charger in power supply mode will also do.
Less than £30.
We all have 220Ah packs here. I seldom use PL8 now.
Postby martin007 » 19 Oct 2025, 16:43
Less than £30.
Could you expand on this a little more?
He means PL8s hard to get.
And so he uses a GOOD BMS + the ZXD (or other olde lead type charger) externally together as a charger. The chair has the same 9 pin balance and 2 wire charge wires.
He just adds a BMS as well as a ZXD in order to balance cells. Not on the chair.
Postby saker98 » 19 Oct 2025, 18:32
Less than £30.
Thank you Shirley,
Please see PM
saker98
Postby Burgerman » 19 Oct 2025, 21:09
Something like this, 2A balance, BT 8S etc.
https://www.aliexpress.com/item/1005007 ... in_prod%3A
Postby saker98 » 19 Oct 2025, 21:33
Burgerman wrote:Any that can do 8S or greater. The more power the better as you are charging a large battery.
Does this https://www.rccarshop.co.uk/x8-icharger-x8-30a-charger-p?srsltid=AfmBOopbWPRdcwrzhZzYGdtxtjmBIyvZW6qn43UMj3GOioR4shJaTqsE have enough power?
James
saker98
Postby Burgerman » 20 Oct 2025, 00:20
Look at it like this.
230Ah battery. Actually those are 244...
So if its fully discharged (it shouldnt be! :fencing ) and you charged it with that charger at say 25A. Then it would take about 10 hours. Chances are that it will be about 2/3rds discharged, so about 6 or 7 hours. Plus balance time. Again that shouldnt take long after initial build and balance.
Postby emilevirus » 20 Oct 2025, 00:49
That's what I use. Works fine. Just don't charge at max. Charge at 25A. Leave some headroom.
emilevirus
Postby saker98 » 20 Oct 2025, 09:22
Hi, what is the connection cable between the charger and battery pack Sub D lead (9 balance and 2 power) lead.
I have the battery to Sub D (9 balance and 2 power) lead
I need a cable Sub D lead (9 balance and 2 power) to charger port?
James
saker98
Postby Burgerman » 20 Oct 2025, 10:54
Yes. Use 12awg silicone for the charge wires.
cable stuff...
one on chair, one on charger
male or female
Male or female
Soldered
Postby saker98 » 20 Oct 2025, 19:13
Burgerman wrote:Yes. Use 12awg silicone for the charge wires.
I am going to go the ICharger x8 route with Shirley's ZXD2400 3.2" TFT and the above cables.(John's Photos)
This way it will hopefully alleviate any further pit falls or mistakes.
Thank you John, and everyone else for their advice and wisdom :worship :thumbup:
Regards
Saker98
saker98
Postby ex-Gooserider » 21 Oct 2025, 01:32
One minor suggestion for more flexibility...
I forget the exact JST "families" but the PL8 uses a different family for the balance connector than the one used on most other chargers, and it is one that is mostly not available pre-wired, and is a somewhat difficult one to home build... IMHO the PL8 connector is somewhat less robust than the more common one, and obviously would be harder to repair since you'd have to take the charger apart to do it.
Given that PL8's are probably going to be harder and harder to get (Despite Shirley's best efforts) I would suggest that people consider making any new cables with the more common JST connector (which are readily available pre-wired) and make an adapter cable to connect that to the PL-8.... It would reduce the number of connect cycles that the PL8 connector would need to handle, and move any failures to the more easily repaired standard connector.
Yes, this will cause some increase in resistance, but it seems to be a common practice for many of the hobby chargers to have an 'adapter board' to fit between the charger and different voltage (and number of balance wires) packs, so presumably not a big concern, as each balance wire would presumably be seeing the same resistance increase, so no net change.
Postby Dan » 21 Oct 2025, 09:43
Burgerman wrote:Something like this, 2A balance, BT 8S etc.
In the wiring diagram for that BMS the charger is the power supply but what is the controller?
Dan
Postby Burgerman » 21 Oct 2025, 09:48
Beats me!
Postby shirley_hkg » 21 Oct 2025, 10:02
It means the LOAD.
Postby snaker » 21 Oct 2025, 10:04
The "controller" means "consumer" or load.
Users browsing this forum: emilevirus, Juggler258, Seafighter, Superchunk and 478 guests
