JK bms settings
Thanks Shirley
I've programmed it. Now just to hook up a PSU... I currently have one that's 16A at 48v that should do ok for now.
JK bms settings
rune wrote:I am using the JK-PB2A16S-20P
It's 200A, has the screen and extra interface bits and power on/off button. The Salsa M2 battery box I am fitting it in has space for it beside the battery without issue. The battery fits with it's longest sides orientated front to rear. I think these inverter BMS's are their latest spec models. Docan were able to supply this with the cells, so I didn't need to pay any extra shipping from China.
Yes, the 16s20p configuration is overkill, but it's what Docan had and going for the this means I get 2A balance and 200A rating. It also has two programmable relay outputs that can be triggered on various conditions, that I might use. I am thinking of connecting one to an inhibit line so that it's not possible to drive the chair when it has the charger plugged in, for example.
Does 8S and 2A balance, although it isnt what it seems. Thats only 2A if its way out of balance. The PL8 is only 1A but it balances at 1A even if its just 2mV spread so its way faster and more accurate.
Raro wrote:Rune, what type of cells did you buy from Docam? Can you post a picture of the cells installed with the BMS?
Charge at 8x 3.550V ideally. 28.40V. 40A. Or 50...
rune wrote:Those of you using the JKBMS, what are you using for a power supply? The data sheet and instructions suggest you can use a dumb power supply of anything from 20-70v However, is anyone using one at 48v or even higher for a 24v pack?
What I am unclear of is should the PSU be a few volts over the pack max voltage and no higher or is it, a few volts over the pack and anything up to the max which is 70v on my BMS. >Clearly higher voltage has an advantage here.
So, is anyone charging their 24v pack with, say, a 48v or 60v PSU with the JKBMS?
Only do big currents with the rear Anderson!
rune wrote:max voltage and no higher or is it, a few volts over the pack and anything up to the max which is 70v on my BMS. >Clearly higher voltage has an advantage here.
Re: "Simple" solution for Lithium charging
PB series "inverter" BMS's are more advanced than the old ones. In fact I have read that they do provide full charge control whereas the older models do not
rune wrote:Thanks Shirley. Either the PSU I have is faulty or it cannot handle an initial surge of high current and just shuts down instead of regulating the current as when I plug it in, it just shuts off the output anyway. Not great :-(
I am interested in these PSUs that BM said you could supply. Is this something you could help me with? I'd be interested to know the cost and how to order.
Thanks!
snaker wrote:"Inverter" JKBMS is designed for solar systems, it's a lot bigger than normal JKBMS. It can work for e-vehicles but almost the same as a normal JKBMS. Its advanced features are only when using with a solar inverter.
Just buy a dumb 8s charger with an Amps rating you want (e.g 30A). Or better a power supply that can adjust the output voltage and current (more expensive). All should be fine. It's not too complicated.
rune wrote:In case this is helpful for anyone:
If you are running your chair power through the BMS, make sure you set the charge minimum temp setting really low, like -20 or something. Why? Well because if the batteries are below the set value and hence the BMS turns off the charge MOSFET, current can only flow in one direction; battery to power module. When the the motors are in "overrun" (is the term overrun valid with electric motors?) , i.e. chair driving motors not motors driving chair, the generated current is not controlled as it doesn't have the battery acting as a sink because the discharge MOSFET is acting as a diode and only allowing current to flow from battery to BMS and not from BMS to battery. Because this causes the voltage to be higher than the preset limit in the power module, it trips the overvoltage protection and you get an error on the pod. In my case, 10 flashing LEDs. Once the temperature measured from the batteries climbs above the low temp protection recovery value, the chair behaves normally again.
Guess how I know this![]()
The chair was left in the van overnight and it was about 3 deg C when my daughter tried to go into town for the first time since I finished working on it. Confusion ensued, util I suddenly connected the dots with the fact it was an over voltage situation and a couple of threads I'd been reading on here last night.
So, when the chair is being used, at all times you need current to be able to flow both to and from the battery.
Users browsing this forum: acid_coke, LROBBINS, Seafighter and 398 guests
