Jay_x wrote:So to answer my question, there is no lever on these older models. You have to undo the clutch lever at the beginning of the chair and then unhinge the chain if there's enough play
If there's not enough play then you have to physically remove the brake system On the newer models they just have a button you can press, so as usual Bounder updates about 20 or 30 years after everybody else does
emilevirus wrote:I just got a smaller sprocket for mine. It's just a standard #35. $10 for 2 sprockets.
emilevirus wrote:Jay_x wrote:So to answer my question, there is no lever on these older models. You have to undo the clutch lever at the beginning of the chair and then unhinge the chain if there's enough play
Easiest way would be to ask Bounder themselves. They'll tell you the easiest way to do it.
emilevirus wrote:https://www.wheelchairs.com/resources/pdf/pricelists/replacement_parts_service_order_form.pdf
Mine is brand new. Came overgeared. In snow it just won't move at all.
your bounder doesn't move in the snow at all?
Burgerman wrote:Just power the system via its charge port. Dont drive the chair... Or jump cables to the battery. Or directly connect to the brake wires and add power.
Users browsing this forum: Superchunk and 356 guests
