emilevirus wrote:your bounder doesn't move in the snow at all?
I added wider, agressive tires as well so all that combined. It barely moves.
how much snow are we talking? Are you just on sidewalks or streets?
Burgerman wrote:Wait and see. You will find that even 1 tooth makes a huge difference. 2 will be much more than you expect. I have much motorcycle chain experience! Your chain will be too long, tensioner will not cope. In any case you shouldnt really run old chain on new sprockets.
Not sure if yours is 1/4 or 3/16th, 3/8ths pitch?
Looked it up. This. 3/8ths. I think. 5 meters or 6 yards. 17 feet! Enough to do both sides twice. £27.
https://www.thebearingcompany.co.uk/pro ... 3-8-pitch/
They do SINGLE link joiners, and double (normal) link joiners too.
But if you know what you are doing you can shorten a chain easily too. But now is the perfect time to replace with new anyway as industrial chain is really cheap like the sprockets.
Tell me what reasuringly expensive price do bounder charge for their sprockets and a chain?
I just went from 23t to 19t. Didn't need to touch the chain. Tensioner has actually A LOT of play.
because that sounds likely.Motor speed depends on load and voltage, it has no "awareness" of RPM and normal controllers do hot have encoders for RPM either. If load is high on one motor, and low on the other, the unloaded one will turn faster.
Does the chair go straight if on a flat, smooth surface? If not, you may have to change motor balance as Shirley suggested or re-calibrate the joystick if it is actually sending "go left" when the stick is centered.
Users browsing this forum: Bing [Bot] and 355 guests
