Hi all,
I'm looking for some advice on R-net OEM Programming for my sports chair. My settings are pretty much maximum for torque, drive, forward, reverse and turn using 90 deceleration and maximum 100 acceleration.
I noticed the output voltage is 26v ATM which seems to make it more responsive but kills the battery quicker.
SERVOS???I have left it at this level. My compensation is 60 which does enough power wise. I also noticed the servos are 2 10 2 10 2 10, should I change these?
Finally, I noticed there is rpm in the encoder settings but feel pushing that beyond the default could break the motors.
Are there any other considerations or settings I should be considering? I appreciate changing things like voltage could cause my battery to die faster but I'm looking at fast charging options for that separately.
Thanks!
So basically, by upgrading to lithium, I'd get more consistent power?
I'm also guessing I should drop my voltage to 22v to keep my batteries charged, since it's pretty much overkill at 26v.
Power soccer chairs' speed are limited.
They need fast pickup and swing the front bracket very hard to slam.
Lithium will certainly be better. High C cells are preferred to high capacity in this scenario.
So another question... With these changes come a lot of heat.
I've been researching whether a push or pull method works. Apparently, pushing air on would be more efficient and cool the motors better. I do have a couple of 5V running off a powerbank atm on the rear bar of the chair, but they're not good enough. I've since found a CPAP battery which has a 24V DC port. I then found some industrial Noctua fans which seem good from a pressure, efficiency and durability approach. There are also Delta fans, but they're very power hungry, which would kill my supply instantly (though this could be offset by fast charging the power bank between games). Would anyone know which airflow config would work best?
Users browsing this forum: emilevirus and 524 guests
