walksonwheels76 wrote:My wife has a quickie q700 with the sedeo seating system. It elevates, tilts reclines and the foot plates also elevate and retract. For the second time in two years with this chair the elevate motor has gone bad. We know we need a new motor. My question is the chair right now is slightly elevated which makes her seat recline function only work one way. It is currently reclined all the way back, normally the seat back will not return to the upright position if the seat is elevated, so we are assuming that is why the seat back won't return to the upright position. The chair is currently unusable in this state. Does anyone know of any way to get the seat back upright either manually or bypassing the sensor which is keeping the back from returning to the upright position. We have just ordered parts to fix the elevate but who knows how long that will take. She relies on this chair and cannot use it at all the moment. Any help or ideas would be appreciated!
Yennek wrote:walksonwheels76 wrote:My wife has a quickie q700 with the sedeo seating system. It elevates, tilts reclines and the foot plates also elevate and retract. For the second time in two years with this chair the elevate motor has gone bad. We know we need a new motor. My question is the chair right now is slightly elevated which makes her seat recline function only work one way. It is currently reclined all the way back, normally the seat back will not return to the upright position if the seat is elevated, so we are assuming that is why the seat back won't return to the upright position. The chair is currently unusable in this state. Does anyone know of any way to get the seat back upright either manually or bypassing the sensor which is keeping the back from returning to the upright position. We have just ordered parts to fix the elevate but who knows how long that will take. She relies on this chair and cannot use it at all the moment. Any help or ideas would be appreciated!
Assuming you have the Sedeo Light or Pro seating (and not the Advanced), you might try temporarily swapping around the connectors on the ISM between something that works, (maybe footrest elevate?), and the backrest and see if that can get it moved back to a usable position. Depending on the programming, the current limits for the footrest might be set way lower than the backrest, so probably best to do it with the chair unoccupied so you don't accidently trip the overcurrent protection.
Option 2, if you are more electrically handy is to just jumper the recline motor directly to 24v to get it back to where it needs to be.
walksonwheels76 wrote:So the footrest elevate works properly, how would I go about swapping those connections? Are they under the seat?
Users browsing this forum: Williamclark77 and 473 guests
