emilevirus wrote:Sooooo I switched to R-Net to try. Only thing left is compensation. On linx it's set to 195mohms. What would be a good starting point for R-Net. 90? I don't get why it's so high on linx.
I tried 195 but it's waaay too high. It wanted to move by itself. 150 is still too high. 110 seems better. It doesn't want to move by itself at least. It's annoying to fine tune though. Always have to unplug, open software, close, reopen etc.
Burgerman wrote:And remember that AMPS are directly tied to torque. Double the Amps, and you get double the torque. Theres 2 ways to do that. MOTOR resistance (impedance). Or Voltage applied. So you WANT low impedance motors. Those make a lot of torque, at LOW voltages. And they also make the compensation additive amount work much better and because it doesent need to ramp up to a high voltage its better controlled and faster to happen.
Well yes and no. Torque is directly related to the magnetic flux. Magnetic flux is related to the current, but the structure of the motor also has a large impact on the flux as well. One way to change the flux is to change the magnetic strength of the stator magnets - this would increase the torque (but would decrease the maximum speed), if everything else is kept the same. The other way is to change the amount of flux generated in the armature.
But. Why are you shutting it all off etc? I fine tune this with a laptop on my knee. As I roll.
R-Net can pull way more amps from the battery than Linx. Linx caps at 100A while I've seen R-Net peak at 140A. If going downhill, R-Net applies the brakes before the chair stops. No big deal for me but it'll wear out the brakes quicker for sure.
Users browsing this forum: Andrey, Bing [Bot], jehan, tettralytic and 612 guests
