Idea's needed for headswitch mount
Postby fishinjunky » 14 Mar 2026, 16:01
I use two egg switches to operate tilt and recline. I have them mounted on my headrest with a Ram mount where I can hit the them with the side of my head. The Ram mount is bulky and far from ideal.
For my new chair I'm looking for a mount that is made for mounting switches to the headrest. I would like the switches to be one on left side of headrest Pad and one on the right.
I have only been able to find the headswitch mount made by Stealth Products (SAR2B series).
Anyone have any ideas or other mounts?
Stealth Products headswitch mount scroll down page to see SAR2B series
https://hs.stealthproducts.com/sar/#low
Re: Idea's needed for headswitch mount
Postby Burgerman » 14 Mar 2026, 17:48
Wouldnt a simple U shaped headrest pad of the correct shape work. With simple smooth momentary push switches each side drilled through. Connected at the rear.
Many here.
https://www.aliexpress.com/w/wholesale- ... l.search.0
Postby LROBBINS » 14 Mar 2026, 22:51
Rachi used a homemade 3-switch mount. Two at the sides on spring-loaded arms so they could not injure her when she had a neck-twisting spasm, and one embedded in the center pad of her headrest. It's much less bulky than what you've been using. I'll post a pic or two, but you'll have to be patient as I'm very involved in adapting what was Rachi's computer system for use by another handicapper with a different spectrum of abilities.
Ciao,
Lenny
Users browsing this forum: Bing [Bot], DennisinTexas, rollingcowboy, ukralex and 275 guests
