ex-Gooserider wrote:My experience w/ the PL8 feeding it from a typical fixed voltage 'shoebox' supply is that the supply maintains a constant voltage (combination of the rated voltage and the setting of the 'trimmer' adjust pot, I find will get about 27V from a 24V rated unit) and varies the current from Zero to it's rated value (likely higher would be possible, but risks shutdown or smoke escape...)
A server supply should do similarly, remember you can control voltage OR current, but NEVER both at the same time (a law written by some dude named Ohm...) and if it's putting out a fixed voltage it MUST be able to vary the current output...
Is there any reason one can't use the JKBMS or similar unit the same way one uses the PL8, namely attaching it to the power supply and making a connecting cable to the chair with power and balance wires?
It seems like this might make a good 'travel / portable' unit as it is seemingly smaller and possibly lighter than a PL8... I could easily see a smallish box with the BMS and a shoebox supply as opposed to the big box I have with the same supply, a PL-8, and a laptop along with it's charger... All of which takes a good bit of setup and table space, as opposed to possibly a smaller box with an AC cord coming out one end and a charge / balance cable the other...
I've also been talking about my lithium conversion w/ the local WC support group, and see a distinct possibility that they will want me to make conversion packs for them - in which case I will need to make a low-effort easy to use way to charge the pack as well - since our supply of PL8's is limited at best, so this would be a good way to handle it...
emilevirus wrote:But it already exists... On Aliexpress USB C to XT60 240W.
Ah I guess it doesn't autostart though.
Burgerman wrote:Because most hobby chargers have a warning inc iCharger to always connect the input power before the battery to the output. Or (looking for pic of a mushroom cloud icon)...
Connecting method:
1. Connect iCharger's input power supply, and turn on it.
2. Connect Li batteries' balance port
3. Connect the main charging port's positive pole to cells' positive pole, and then connect negative pole to
cells' negative pole (this will avoid striking fire while connecting Li cells).
4. Start charging and discharging...
5. After finishing charging and discharging, pls disconnect the cell and charger, and then turn off the charger's
power supply.
emilevirus wrote:You could just add a relay no?
BMS is good enough for routine recharge.
Connect a Balance charger for maintenance from time to time.
Superchunk wrote:
that sounds simpler than it is given 30A 28V charging and for both the xt60 and the balance lead.
Not sure I see what the aim is?
30A x 28V is 840 watts. Plus 10 or 15% losses in the conversion in the charger and the USB inverters seperately. Means 840 + say 20% minimum. So over 1000 watts.
Where is this coming from? Cant be from USB?
Burgerman wrote:The real issue is how much to put back? And how long have you got?
Remember a full charge on a 244Ah lithium (the 230Ah cells) x about 26V is a huge 6,300 watt hours. So 6.6 hours inc balance at 1KW charge rate. Or 6.5 hours at 37 Amps...
Fortunately its infrequently that we have an actual empty battery.
At 5A charge, that will take err... Just over 49 hours. We get only 8 overnight!
emilevirus wrote:Why not just a BMS with a 10A lifepo4 charger. They're pretty small. https://www.aliexpress.com/item/1005009862077115.html?
Superchunk wrote:emilevirus wrote:Why not just a BMS with a 10A lifepo4 charger. They're pretty small. https://www.aliexpress.com/item/1005009862077115.html?
might as well just use my permobil charger then.
Users browsing this forum: fordragon88, shirley_hkg and 172 guests
