emilevirus wrote:Your laptop CPU dumps more watt than that and fan isn't loud. Good quality fans don't whine. They just whoosh.
He wants a type-C PD as well.
Chair's electronics are connected. I won't apply 48v to it.
What are you aiming at, other than plug and charge by carer?
would I be able to just put 48V@5a usb c to JK BMS? Will it charge or just cut off high voltage? If the latter, Can I not just add a buck converter then plug into bms by xt60?
Burgerman wrote:would I be able to just put 48V@5a usb c to JK BMS? Will it charge or just cut off high voltage? If the latter, Can I not just add a buck converter then plug into bms by xt60?
You would have a large impedance mismatch. The battery voltage will control the charge voltage. So it will "pull down" the 48V to thenominal 24v level and may damage the 45v supply or cause it to shut down as if it was short circuted. If it doesent do any of that then your supply that was 200 watts at its 48V is now 100 watts to the battery and the rest is wasted. So you may as well use a 24v nominal system like a laptop charger.
You can safely charge a AA cell directly from the wall AC with a simple diode and a resistor. Its the same thing. But more than 99% of the energy goes to waste as heat in the resistor. In your case half the power is wasted as heat in the inverter. Which it may sense and shut off. Or overheat.
Burgerman wrote:In order to have 240 watts with a small supply like the USB PD you need 48V. All the components and wires would need to be double the size to do it at 24v.
But your battery is 24v. So now you would need another inverter and lose another inverter to go from 48 to 24 and lose another 10 to 15% in order to reduce voltage and double the current. Which is as big as your 240w PD box... Then you need to feed that to the BMS in order to balance etc which is physically big again. You end up with something as big as that charger above or the ZXD+BMS or a hobby charger like I already linked to.
So not really sure what you want. I think this fixation on a 48v PD thing is your problem. Its not useful.
Your device must be CC/CV capable, when it comes to charging battery.
You have 2 main cables and 9 balance wires all connected to your X8.
Compact medical grade switching power supply + buck / boost conveter will it help ?
How do you find the result of JK BMS so far ?
Burgerman wrote:All balance wires.
Bath it in 45℃ as well will increase efficiency.
29.4V charge (bit high but BMS will handle it)
32-85V input isolated
8A output
Burgerman wrote:I dont get this PD fixation.
You now need a PD device thats quite big. This new gadget. And a pretty large BMS... All to charge at 8A or a bit less.
What is the aim?
And...29.4V charge (bit high but BMS will handle it)
8A output
They do a 28V one. Which is a perfect 3.50V per cell. Then it wont do as much harm to the battery.
That tiny charger I linked above or something similar from the hobby world does all 3 of these things, in one box, and gives a USBC output to charge your gadgets. And will charge better and balance faster too.
Burgerman wrote:But the whole point is that he doesent want to take it.
emilevirus wrote:My chair has an integrated charger. Only 5A but it gets the job done. Will charge a lifepo4 to 99% and doesn't balance. Fine when I go on a trip.
Superchunk wrote:emilevirus wrote:My chair has an integrated charger. Only 5A but it gets the job done. Will charge a lifepo4 to 99% and doesn't balance. Fine when I go on a trip.
Which charger?
Users browsing this forum: No registered users and 91 guests
