Good morning, I imagined it is not easy. Then there is no possibility to implement a command if you do not have joysticks and R-net programmers. Can't I send data with CAN-bus protocol and enable outputs? Has no one been able to code the commands for that control unit? Thank you Denis
Good morning everyone, I wanted to ask if it's possible to reprogram the MKIV GB control unit to remove the speed limit that kicks in at about 12.5 km/h and decelerates the wheelchair to a stop.
Perhaps it's possible to modify the control unit to increase the rpm and speed?
I'm attaching photos of the control unit and the new 280Ah LiFePO4 batteries, which greatly increase the range of the 4x4 wheelchair, especially on uphill roads where I live in the mountains!
Thank you for all the advice and information you've given me.
Thank you
Good evening, I've tested the "Invacare MK4 GB Power Wheelchair Control Module 1109528" controllers with different firmware versions. When I programmed them all the same at 100% speed, only the one in the attached photo reaches 190 rpm.
All the other controllers reach 160 rpm. This means the maximum speed is set by the firmware written into the controller's processor. I need another controller that reaches 190 rpm.
I'm wondering if it's possible to update the firmware on these controllers.
Best regards and thank you!
I doubt it's possible. Brushless motors commutate electronically by passing current between different pairs of electromagnetic poles, and it's the commutation frequency that determines the speed. GB motors have multiple electromagnetic poles to replace the missing gear. I don't think there are any other controllers capable of managing them, and Invacare certainly wouldn't indicate how to change the commutation frequency even if it were possible. Sorry. Bye from Siena, Lenni
I'm assembling a new wheelchair, still with 4WD, so I need two controllers that I can program with my programmer at 100% speed, both rotating at 190 rpm.
Unfortunately, only one reaches 190 rpm.
I'm trying to purchase one, but they're now hard to find, and I'm not sure if they'll reach 190 rpm at 27 volts because it depends on how Invacare factory-programmed them.
I saw that there are two models:
1) Invacare MK4 GB Power Wheelchair Control Module 1109528
2) Invacare MK4 GB Power Wheelchair Control Module 1079889
Does anyone know the difference between the two?
How and where can I find another controller like mine that reaches 190 rpm?
Users browsing this forum: Yennek and 286 guests
