>>>1. all the ring terminals for interconnect, power and balance cables are only crimped and no soldering. The only thing that is soldered is the D sub connections. I'm attaching a picture of the crimp
I haven't tried charging the pack, but when I try to monitor the pack, it detects all eight cells but only shows voltages for seven cells and then immediately diminishes to 5 cells, three cells , one cell and then shows a BAD CELL COUNT and stops monitoring.
That so-called faulty one was free of charge, except shipping.
LROBBINS wrote:I have two 208 AHr packs, one in what was Rachi's chair and still hasn't found a home, the other kept in the garage as a spare. Given that they are unused and unconnected, I charge them once every 6 months an discharge to ca. 70% for storage. The one on the garage floor does get kicked about some. The last time I went to re-charge that pack it gave nearly the same faults as Jehan has described. It turned out to be an intermittent balance lead, but not because of a bad (soldered) connection to the ring terminal. It was a fracture of the balance lead itself near the ring connector. So - do follow John's advice and solder your connector, but also jiggle those wires about a bit while the PL8 is trying to read the pack just in case the same thing has happened to you as happened here.
jehan wrote:Hi…
I have charged the cells individually to terminate at 100 MAH CV and installed in the chair.
After three days of use, the voltage is 26.6 V.
I am trying to charge the pack unbalanced.
Users browsing this forum: emilevirus, jefferso, martin007, rover220 and 398 guests
